Giac Race File
Giac Race File
It Seems Giac Does Not Sell The Race File By Itself. I Have Been Told You Have To Buy The Stock File With The Race File For 650.00. I Have No Reason To Have The Stock File. Does Anyone Know If It Is Possible To Obtain The Race File By Itself?
Originally Posted by roadsterdoc
PaulieW- What if you need to fill up in an emergency situation and there is no race gas available? Having a stock file would save you. Just something to consider.
pump file (what he has) pump gas 1.2bar
stock file (what they want him to buy, but he doesn't want it) pump gas .8bar
Paul, you might have to bite the bullet and get the race and stock file...unless you go zero clearance with kevin
wash up those rides and See you guys (Paul and Doc) 2morrow
Originally Posted by drjoe
Race file (what he needs) race gas
Originally Posted by wross996TT
Aren't you the one that is pimping the octane booster....and you just have the stock ECU. Octane booster will not help you with that ECU.
Only thing at my house that needs race gas uses only C16
The Vette runs on 93. I just have friends with turbo cars.I've heard though if I added some VP Import my car will pick up like 150whp because of the massive amounts of octane
Originally Posted by Powell
Never said I could use it. I've said it like 15 times
So what is the turbo in your sig? And you just posted your hitting .6-.7? WTF?
What
So what is the turbo in your sig? And you just posted your hitting .6-.7? WTF?The Camaro has to have C16 for the nitrous. I have an enrichment tank for the nitrous and a fuel cell for the regular fuel.
It depends on your ECU/DME code, but right now GIAC has a 3 program combo for most 996TT's; pump gas, race gas, "stock." You have to at least have the GIAC pump gas file in order to add race. I believe they're working on making it u-choose so you could just get the pump and race.
HTH
Originally Posted by amg e55
Paulie,
HTH
HTH
Thanks fot the clarification, drjoe. So do you really think that they charge for the stock file? I doubt it, and imagine that to ask for programming without it will cost the same as you are paying for the proprietary software and not the oem software.
