996TT Limited Slip Diff question
Old Feb 12, 2007 | 11:06 PM
mepayne1's Avatar
mepayne1 is infamous around these parts
Was a Limited Slip Diff a factory option for the 996TT? How can I tell if equipped?
Old Feb 12, 2007 | 11:19 PM
tom kerr's Avatar
to my knowledge the original AWD set up doesnt really need the limited slip due to the distribution of power for the AWD set up. when some guys go to the RWD set up for this car you do not have a "limited slip" in the rear. This is then added to upgrade your RWD setup at a good increased expense.
Old Feb 12, 2007 | 11:43 PM
mepayne1's Avatar
Thanks Tom,
I understand that the AWD system directs some torque to the front wheels but, wouldn't adding a LSD to an AWD turbo help from side to side?
Old Feb 12, 2007 | 11:50 PM
tom kerr's Avatar
Originally Posted by mepayne1
Thanks Tom,
Have to admit I am no tranny expert just giving you the info I have received while looking into the RWD conversion. Again, I really think in true AWD trim all the PSM and yaw control and AWD work in synergy. But I'm sure someone on here has done it!
Did some research for ya and it is an option on the 997TT option 220, I dont know about my car.
here is a little more from somewhere else from a search...
Porsche's front-wheel drive axles come in if the rear differential starts to slip. So theoretically, one could do without. but why not get the LSD for the $950 and by pass all that rear-wheel slippage on wet pavement or going into tight turns. I am surprised not available with auto-trans, but who needs/wants absolute traction with slush-trans anyway.The factory installed LSD doesn't interfere with the cars PSM and PASM systems, but installed later may interfere.
Old Feb 13, 2007 | 12:14 AM
mepayne1's Avatar
Thanks again Tom,
I'm certainly no expert. Just trying to get a better understanding of how it may or may not work. I appreciate the info.
Mike
Old Feb 13, 2007 | 01:03 AM
cjv's Avatar
cjv
Moderator
Porsche did not offer LSD's as an option on the 996tt.
Old Feb 13, 2007 | 01:22 AM
Oliver B's Avatar
Oliver B is infamous around these parts
In germany you could get the LSD 220 for the 996tt but only with x73 -20mm.
Old Feb 13, 2007 | 02:26 AM
03-turbo911's Avatar
Senior Member
The LSD option was available in the ROW market for the '05 996 turbo S.
Old Feb 13, 2007 | 07:41 AM
ze_shark's Avatar
ze_shark is just really niceze_shark is just really niceze_shark is just really niceze_shark is just really niceze_shark is just really nice
Probably to avoid inducing more understeer, which these cars are not in shortage of already ! I drove once for an hour a 997S fitted with the sport chassis and the optional LSD, and this was a real sleigh. No way to carve a smooth curve in that thing, the front would push wide all the time.
Jul 29, 2019 11:13 AM
Sep 14, 2015 06:42 PM
The Oss
Aug 24, 2015 08:19 PM
Aug 20, 2015 12:17 PM
