Newbie Question
Old Feb 15, 2007 | 10:42 AM
vividracing's Avatar
Newbie Question
Hey everyone..
I just removed the factory nav setup in my 01 996TT, for sale btw. I instaleed a Eclipse AVN5500. Looks and works great. Problem is now the clock on the dash next to the speedo resets itself to 3am every morning I leave to work. So the car is obviously off and not sure if it has a memory wire or something connected to the old unit? Also when I push the button in to set the clock, it goes to the hour, then i turn it and it will turn the minute and hour each click. So where before you would set the hour and push it in to set the minute, it does this.. Hour minute hour minute. Does not matter what I do...
any help or guidance from the stereo gods is appreciated.
Old Feb 15, 2007 | 10:58 AM
esemes's Avatar
esemes is infamous around these parts
I had a clock issue too. (when i replaced the batt).
i just did a "reset" by disconnecting the battery for 10 minutes and then it returned to normal operation.
HTH
Old Feb 15, 2007 | 11:00 AM
hmmmm will try. It has been in there for 2 weeks.
Old Feb 15, 2007 | 11:40 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
flip the red and yellow cables. yellow is memory and red is ignition. I had the same problem. I b et your bass and treble settign arent holding either. try it out an dlet me know. thanks
-Suman
Old Feb 15, 2007 | 11:42 AM
Will do. Thanks Suman!
Old Feb 15, 2007 | 03:18 PM
yeah that was not the problem.... Everytime the key is pulled out, the dash lights stay on as normal. Then they go off, when you put the key back in, the clock comes on flashing????
PV=nRT.
Sep 9, 2022 06:06 PM
takenotes996tt
Jan 20, 2016 06:34 AM
HotRod
Sep 10, 2015 07:17 PM
pjb84
Sep 2, 2015 12:57 AM
