How to determine Baseline height for the PSS9 ??
Old Feb 26, 2007 | 09:39 PM
Mz3bo's Avatar
Mz3bo is infamous around these parts
Hi,
I read many thread about the height that i should put my 996tt at with the pss9. However, when they say xxx, (mm) , what does that mean ? should I mesure on the strut iself or the gap between the wheels ? I mean, how can you get a perfect and accurate height from one side to the other, you just need to turn the ring one turn over and the car will be a little higher....
Old Feb 26, 2007 | 10:17 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
Hope this helps:
Old Feb 27, 2007 | 08:53 AM
And here are some measuring numbers if you don't already have them:
All with 18" wheels:
Turbo USA: 158 +/- 10mm Front. 163 +/- 10mm Rear.
Turbo RoW: 138 +/- 10mm Front. 153 +/- 10mm Rear.
Turbo X73: 128 +/- 10mm Front. 133 +/- 10mm Rear.
GT2: 118 + 5mm Front (118-123). 133 + 5mm Rear (133-138)
wrs
Nov 17, 2016 06:53 AM
alpha motoring
Oct 2, 2015 12:04 PM
Sep 28, 2015 02:19 PM
TOGWT
Detailing
Sep 28, 2015 08:25 AM
