Safe Mode
Car went into safe mode today. I tried cleaning MAF which did not work. I had the plugs changed about 4-5K ago. The idle seems about 100rpm above normal. The car is a 2003 with Stage 1 and V-flow with 21K mi. No fault codes. Any ideas?
Originally Posted by steve harris
unhook your batt for 15 min or so ( don't forget yoour code) your car will exit safe mode... happened to once this worked are all has been fine since good luck
You do not have to worry about radio code for your year. By you don't have any codes I assume you mean that you didn't throw a CEL or any lights. Yhis does not mean you did not throw codes. Get them read ASAP.
Oct 2, 2015 02:23 PM
TOGWT
Detailing
Sep 29, 2015 07:05 AM
