boost issue
Old Apr 3, 2007 | 05:00 PM
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
boost issue
i have the giac flash and only see 0.8 bar sometimes 0.9. i did change the dvs and no difference.
is there a software tool for these cars where i can log actual boost vs. requested?
anyone have ideas on what it could be? boost leak?....
Old Apr 3, 2007 | 05:37 PM
sechsgang's Avatar
sechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant future
that sounds...normal...was the chip supposed to increase boost?
Old Apr 3, 2007 | 05:51 PM
drewTT's Avatar
yes, it is the giac 1.0 bar file. it should be doing 1 bar all the time.
Old Apr 3, 2007 | 05:55 PM
sechsgang's Avatar
oh...well then...I guess contact GIAC about it...or bring it to a shop to check for leaks.
Old Apr 3, 2007 | 08:09 PM
FlyingLow's Avatar
FlyingLow is infamous around these parts
Drew, have your local giac dealer check it out. I have the same giac flash and see 1.0 all the time, I've even seen 1.1 a couple of times.
Old Apr 3, 2007 | 10:00 PM
drewTT's Avatar
do you get a consistent 1.0 bar when flooring it in second and third gear?
i only seem to get 0.9 at best right towards the top of the powerband...
Old Apr 3, 2007 | 10:13 PM
FlyingLow's Avatar
Pretty consistent, especially on colder days/nights. I've heard that the stock boost gauges are not that accurate so you might not even have a problem other than the gauge itself.
PV=nRT.
Sep 9, 2022 06:06 PM
Paintballzen
Oct 10, 2020 12:22 PM
Rguy
Apr 12, 2020 11:11 PM
Rockinc1
Sep 30, 2015 06:44 PM
