Proper procedure for 60-130 runs
Old Apr 4, 2007 | 05:20 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
I am using an AX-22 and have done several runs with several different results. Basically I am in 3rd gear about 50mph then get on it, so by 60 i'm at full boost and then 1 shift into 4th all the way home. Is this correct or should I be doing something different. I'm getting times from the 6's to the 8's.....
Old Apr 4, 2007 | 06:00 PM
there is a consensus that the AX22 if not installed and calibrated correctly will give skewed results... if u shift fast use 2nd, 3rd, and 4rth... then di 3 and 4... I would go to 40 mph though in 3rd.
good luck,
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 4, 2007 | 09:48 PM
Dr_jitsu's Avatar
I did conventional 3-4 run but I was on a short 1/4 mile track. If I had plenty of room I would try brake boosting in 4th and just holding to 135 or so.
Old Apr 4, 2007 | 10:29 PM
Craigger's Avatar
Craigger is infamous around these parts
with ETC (fly by wire) if the car sense's brakes at the same time as gas it shuts the TB down.
at least i have been told by sources that
danyoP4S
Sep 30, 2021 05:06 AM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
Fester
Sep 8, 2015 09:35 AM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Sep 2, 2015 02:13 PM
PelicanParts.com
Sep 2, 2015 02:12 PM
