VGT turbo for 996TT -- Will it be possible ?
Old Jul 15, 2012 | 09:57 PM
  #31
Turbo Fanatic's Avatar
I have bone stock 996 GT2 (K24s) and it feels like a 930 when you compare boost and throttle response to the ball bearing Tials on my turbo. The difference in reaching full boost can be measured in seconds. Aftermarket turbos are THAT much of an improvement.
Granted the TT has exhaust, IC, etc... but K24s are boosting a full .4 less BAR (.9 vs 1.3) and taking longer to get there.
These aren't the A28s mind you, the 2860 is a mid range turbo huffing hard at redline, but you can see full boost of 1.3 bar by 3,000 RPM if you load it up in 6th.
Old Jul 16, 2012 | 04:40 AM
  #32
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Get the 24's converted to 24/18's & you will walk away from your turbo.
I ran Jitsu when he had the 28's & I had 24/18's. We started from about 60mph & I left him from the start & stayed in front the entire race.
Old Jul 16, 2012 | 01:28 PM
  #33
RxPorsche's Avatar
RxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud of
Thumbs up
Hi, PAULIEWALNUTS my car is getting K24/18g installed right now with new Gt2RS IC's and methanol. How much WHP was your car producing? Thanks !!!
Old Jul 16, 2012 | 01:57 PM
  #34
johnspeed's Avatar
HI,So you went from K24/18gs to K24/20s....Did you do alot more supporting mods with that change?? Thanks..
Old Jul 16, 2012 | 01:59 PM
  #35
Do you have the extra fuel pump & larger injectors? What about the turbo pipes behind the motor?
Old Jul 16, 2012 | 02:00 PM
  #36
Yes pretty much have all bolt ons necessary to take advantage of the 20's.
Even did external wastegates.
Old Jul 16, 2012 | 02:55 PM
  #37
RxPorsche's Avatar
5 BAR regulator with 60 lb injectors. Forge turbo hoses.
Old Apr 29, 2013 | 06:29 AM
  #38
gclasse's Avatar
gclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond repute
There is a company that is developing a vgt controller. is it possible to have these installed in a 996 now??
Old Apr 29, 2013 | 07:26 AM
  #39
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
There are a number of cars that have been running VTG's for well over a year now .........
Old Apr 29, 2013 | 10:31 AM
  #40
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Yes, there are already cars running VTGs and there's also units capable of controlling them electronically (ie no need to hassle with pneumatic valves).
Old Aug 3, 2013 | 10:47 AM
  #41
Whereitsat's Avatar
Whereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond repute
Anymore news on the VGT for the 996TT?
Old Aug 3, 2013 | 02:49 PM
  #42
pete95zhn's Avatar
The subject is not sexy at all, compared tialsomethings, but what you want to know?
Old Aug 3, 2013 | 03:00 PM
  #43
Whereitsat's Avatar
I'm looking at k24/18's but found a set of 68VGT's. just needing more info to decide which route. Any help is appreciated.
Old Aug 4, 2013 | 05:30 AM
  #44
Talk with Steve at Drivers Source he has done a 996 with VTG's. Todd K tuned it & it runs strong.
Old Aug 4, 2013 | 10:18 AM
  #45
Whereitsat's Avatar
Thanks Paul. You and BHT are on the same thought track. Btw, we're heading over to get the cars washed. Don't spy on us!
