Half-assed oil change a good idea?
Old Apr 19, 2007 | 12:00 PM
Joe Weinstein's Avatar
The mighty vac won't work with a dry-sump motor.
It only clears the sump, not the remote oil tank.
This is the same reason my lazy option won't work.
The sump drain hole won't drain the majority of the oil.
Joe
Old Apr 19, 2007 | 04:02 PM
timf's Avatar
timf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud of
But if you insert the tube....
Into where you pour the oil, does this not lead directly to the oil tank and thus it will vacuum the oil tank dry leaving behind only what's left in the engine sump and turbo's etc ?
COBB Tuning
Jan 1, 2025 09:02 AM
SharkyShark20
Sep 19, 2015 09:54 PM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
