C16 vs. C12: Burn Rates
Old Apr 19, 2007 | 07:12 PM
OhioGT2's Avatar
OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !
Originally Posted by Craig
Thanks Marty. I have been quoted $7.50 per gallon for C12. VP sells several leaded fuels below C12. You might also want to consider VP 109, which is unleaded.
Craig
Craig, can you find out if the rumor of 109 unleaded containing some nitro is true?
I ran VP Import all last summer in my Supra, it was like owning a frickin boat, just a bit faster
Old Apr 19, 2007 | 07:18 PM
Me_qwkr's Avatar
Me_qwkr is infamous around these parts
You calling the supra or a boat.. As i have been suggested to use VP Import
Old Apr 19, 2007 | 07:28 PM
SCM3's Avatar
SCM3 has a spectacular aura aboutSCM3 has a spectacular aura aboutSCM3 has a spectacular aura about
What about Torco, im hearing so many good things about them. I was having my car tuned on Torco 118, now im worried.
Craig how do you like the Trick 101? Ive used it daily for my previous setup.
Old Apr 19, 2007 | 07:30 PM
Me_qwkr's Avatar
i think the trick is good for extra power with a 93 octane tune..
Old Apr 19, 2007 | 07:39 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Craig
VP 109 is actually only 105 R+M/2 according to their spec sheet....Kevin
Old Apr 19, 2007 | 07:41 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Isnt c12 108 octane?
SCM3's Avatar
Also i found out the Torco 118 evap points.
10% 168
90% 208
End point 236
And this fuel has a Pump Octane(R+M)/2 of 118.
Old Apr 19, 2007 | 08:41 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
hasn't this always been the case? never run more octane than what you need? higher octane = slower burning - that's why it's less likely to detonate.
it is interesting to hear about the cooling additives in the C12...
- chuck
Old Apr 19, 2007 | 08:52 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
I have not used the Trick 101 in a few years. It is a great option for people living in the SFV . . . much better than other pump options. I subsequently switched to Sunoco GT 104.
Craig
Old Apr 19, 2007 | 08:56 PM
Craig's Avatar
I am well aware . . . that's why I used the Sunoco GT104 instead . . . 1 point less octane and much less money.
Craig
Old Apr 19, 2007 | 08:58 PM
Craig's Avatar
110 R+M/2
Craig
Old Apr 19, 2007 | 09:00 PM
Craig's Avatar
10% 168
90% 208
End point 236
That is a slow burning fuel.
Craig
Old Apr 19, 2007 | 10:10 PM
Divexxtreme's Avatar
Craig,
Can you please ask Jay or your distributor if C25 would work for our applications? It has higher octane and faster burn rates than C12 does:
Specification Sheet: C25
Specific Gravity: .692 @ 60°F
Leaded: Yes
Color: Yellow
Motor Octane: 113.0
RVP: 9.66
Oxidation Stability (min.) 1440+
Distillation:
10% evap @ 120.8°F
50% evap @ 162.5°F
90% evap @ 207.2°F
E.P. @ 231.6°F
Availability: Sealed Drums
Old Apr 19, 2007 | 10:12 PM
Also, IRT Sunoco 112...it ain't all that. Burn rates are much slower than C12:
Sunoco Supreme Leaded
Antiknock Index (R+M)/2 112
10% Evaporation - 170
50% Evaporation - 219
90% Evaporation - 232
Old Apr 19, 2007 | 10:43 PM
WOODTSTER's Avatar
VP109 == 105 octane unleaded
Sunoco 260 GTPlus == 104 octane unleaded
Sunoco 260 GTX == 98 octane unleaded
thanks,
this is a great thread.
MK
