X50 with Chip and Exhaust - 500whp feasible?
Old Apr 23, 2007 | 01:49 PM
Tech-Law's Avatar
Tech-Law is infamous around these parts
Am I being to optomistic to think an otherwise stock X50 with a chip and exhaust would get to 500whp?
Old Apr 23, 2007 | 01:55 PM
King's Avatar
King is infamous around these parts
Yes.
At the crank, not RWHP
Old Apr 23, 2007 | 01:59 PM
Tech-Law's Avatar
No way it's at the crank. The X50 comes from the factory with 450 hp. That would mean the chip and exhaust only made an additional 50hp? At about $7,000 that's an expensive 50hp for a turbocharged car.
I could see maybe 550 at the crank but 500 seems too low.
Old Apr 23, 2007 | 02:08 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
An ECU upgrade and exhaust, with nothing else, will not get you to 500 RWHP, even with x50 turbos.
Craig
Old Apr 23, 2007 | 02:09 PM
King's Avatar
I thought you meant into the 500 plus range.
I would hope for 550hp
Old Apr 23, 2007 | 02:10 PM
x50plt's Avatar
x50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to behold
I have the same car and have the chip and exhaust and think it increases 65-75 crank hp, but only a dyno will tell you.
adybuncio's Avatar
you dont add hp like chip is 80 + exhuast is 20 dosent not equal to 100hp
Old Apr 23, 2007 | 02:27 PM
Craig's Avatar
Keep in mind that a stock X50 already runs more boost than stock non-X50 (approximately .1 bar more boost). Therefore, when you reprogram the ECU and bump up the boost to 1.1-1.2 bar, the increase is less for the X50, as compared to the non-X50.
Craig
Old Apr 23, 2007 | 06:13 PM
Turbo Fanatic's Avatar
You can get close. Here is my car on 91 octane, GIAC chip, exhaust, evo intake and modified wastegate springs (or upgraded wastegates) underlined because it's crucial.
http://members.dslextreme.com/users/...11%20Turbo.jpg
Old Apr 23, 2007 | 06:45 PM
Dub-U!'s Avatar
Dub-U! is infamous around these parts
Anybody have any details between GIAC K24 programming vs UMW K24 programming on stock K24s assuming exhaust/DV/Wastegate Actuators/filters are the same?
Old Apr 23, 2007 | 06:46 PM
Craig's Avatar
Even with more mods (EVOMS intake and upgraded wastegates), you still did not reach 550 RWHP (although 516 RWHP is mighty impressive), thus proving my hypothesis that, with fewer mods, 550 RWHP is unlikely.
Craig
Old Apr 23, 2007 | 07:38 PM
I doubt K24s can produce much more than 500 RWHP. Maybe 530 peak with race program on a good day. Even so, some of the more influential tinkerers here think that K24s are only good to 550 crank HP.
I can tell the original poster from experience that fine tuning the wastegates can have a very profound effect on boost (throttle) response, midrange torque and overall power.
Craig
Old Apr 23, 2007 | 08:42 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Check with Vincentdds about the UMW k24 programming. He is the only one I can think of that dynoed the car and IIRC it was about 630 at the crank,but I have no idea what other mods were done to the car or type of dyno used. Kevin
COBB Tuning
Jan 1, 2025 09:02 AM
Small Shrimp
Sep 1, 2015 10:51 AM
Mar48
Aug 24, 2015 01:13 PM
Vrseis
Aug 20, 2015 07:41 AM
