PSS9 Question
Old Mar 25, 2004 | 12:44 AM
ebaker's Avatar
ebaker is infamous around these parts
PSS9 Question
I believe the PSS9 shocks are single adjustable. Does the adjustment affect jounce or rebound stiffness (or both)? Can they be adjusted as soft as stock shocks?
Old Mar 25, 2004 | 07:08 AM
msindi's Avatar
both...
I think they can be made very soft...Most people run 3 or 4 (smaller number = harer settiong) but you can dial them all the way to 9!!
Old Mar 25, 2004 | 07:54 AM
JimC's Avatar
JimC is infamous around these parts
Ebaker I understand your Question,I have the Pss9 and ther ads are misleading! the strut /shock is single adjustable in that the compression dampeming and rebound dampening are not independant adjustments the internal valve stack is situated on a commonshaft so as you turn the **** you adjust the compression and rebound together not always the best situation. on my race car I have a true double adjustable shock and have set up soft compression dampening and stiff rebound for the handeling I was looking for but as in life there are always compromises and the pss9 is one of them
Old Mar 25, 2004 | 08:08 AM
JimC's Avatar
Old Mar 25, 2004 | 08:26 AM
james's Avatar
Carolina Speed
james is infamous around these parts
welcome JimC. I noticed Libertyville, Il. You must know Sol at perfect power inc. Check out the thread on corner balancing and road stability.
Old Mar 25, 2004 | 08:32 AM
ebaker's Avatar
The single adjustable Koni's I've had on several cars in the past only adjusted rebound stiffness. I was curious to know if Bielstein's were the same.
Old Mar 25, 2004 | 11:54 AM
JimC's Avatar
Thanx James Yes I know SOL there a great bunch of mechanics at that shop I strongly urge any one in my area to use him as he probably trained most of the mechanics in our area
HotRod
Sep 10, 2015 07:17 PM
MadWhip
Sep 3, 2015 02:04 PM
orbelo
Aug 30, 2015 12:26 PM
LiquidElephant
Aug 27, 2015 06:17 PM
TrackOne
Aug 20, 2015 12:56 PM
