El 750
Old Mar 27, 2004 | 10:24 AM
cjv's Avatar
cjv
Moderator
Cool El 750
Elliot, have your put your beast on a dyno yet? I am really waiting to hear the results. I want to see the whole range as I believe you will be blazing some new territory. Especially in the torque column.
Old Mar 27, 2004 | 12:27 PM
EL750's Avatar
EL750 is infamous around these parts
Tuesday is the day Chad. Put a few hundread miles in the motor today since all components are new. At 1/3 throttle we got 1.2 bar @3800rpm. 1.3 at 3/4 throttle. Response is crazy. Took it up to 5,000rpm 6th gear. Can't wait to let it loose.
Old Mar 27, 2004 | 04:24 PM
cjv's Avatar
cjv
Moderator
Let us know as soon as possible. I believe you are the first that has taken stock heads, added larger valves and did a port and polish job. Should really be interesting.
Old Mar 28, 2004 | 02:36 AM
EL750's Avatar
Chad, I just uploaded a couple more pics.
http://hobbystage.net/porsche/elliot/
Old Mar 28, 2004 | 05:51 AM
cjv's Avatar
cjv
Moderator
Elliot,
Thanks for sharing the pics. Gave me another idea. Those guys at TTP seem to really have it together. I can't wait for your dyno sheets. I may have to take down my motor one more time because of you. Thanks.
Old Mar 28, 2004 | 01:31 PM
HotRodGuy's Avatar
can't wait to see the results!
Old Mar 28, 2004 | 04:15 PM
dbelleperc's Avatar
I soon will be a supporting member
dbelleperc is infamous around these parts
I'll second and third that.
Old Mar 28, 2004 | 06:17 PM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Man that had to have been close to 170 mph by my calculations. Thats fast on a public highway...
Old Mar 28, 2004 | 06:24 PM
cjv's Avatar
cjv
Moderator
I've had KA to 7500 rpm's in sixth. Redline is 8100.
Old Mar 29, 2004 | 12:57 AM
EL750's Avatar
That's cruising speed .....at the AUTOBAHN. Went from Rosenheim Up to Nuerburg and back.
Old Mar 29, 2004 | 04:14 AM
EL750's Avatar
Well it looks like we overachieved targets. There is TOO MUCH low end torque that we have to restrict it by maybe lowering boost to 1bar in the low/ midrange rpm band. The point is to make a drivable/ reliable combo. Using a new Mahn Dyno. More on Wednesday.
Old Mar 29, 2004 | 06:14 AM
cjv's Avatar
cjv
Moderator
Old Mar 29, 2004 | 11:48 AM
ColorChange's Avatar
ColorChange is infamous around these parts
C'mon, you're killing us. Is there really such a thing as too much torque?
Can't wait to see the numbers. Those heads/intakes/valves look wonderful.
Chad, how does KA compare?
Old Mar 29, 2004 | 12:02 PM
HotRodGuy's Avatar
I was thinking the same thing, but I just got an image of the front driveshaft just shredding
Old Mar 29, 2004 | 12:45 PM
EL750's Avatar
We have disconnected the front shaft. Torque crossed the 1000Nm point @4660rpm. The worry is how it responds above 2800rpm. I am very happy with something less. The high lift cams with large valves really push in alot of fuel @ low rpm. Don't want to destroy the amazing tranny. Even with the light mass flywheel there is only some added noise at idle. Steel syncros are nice and crisp.KA is a different animal alltogether.
