ABS, PSM light car stays running with lights on and key removed
My car is whacked. Just got it back and it is worse. ABS and PSM came on again. Brake lights are out.
I can remove my car and my car remains running if the head lights are on. I can then switch my head lights off and it turns my car off.
Any ideas?
Any ideas?
Sounds like a wiring fault or a bad Headlight switch. Something is feeding +12v constant power back into the +12v ign lines and keeping things powered even though you've removed the ignition power. I'd check for any work recently done as well as checking around to see if the ignition or headlight switches fail in this manner. I have not heard of this on any Porsche ignitions, but stranger things have happened. Like I said, my bet is on a wiring issue or rogue headlight switch. Just my 2 cents.....
S****** - I had the same thing on a car many years ago.
My rear side light had gone out, so I swapped the bulb with the brake light. When I got home the engine kept running even with the ignition key out. Somehow or other the bulb had connected the ignition system direct to the battery. When I took the bulb out, the engine stopped.
Any ideas?
Any ideas?
PorscheEnthusiast
Nov 13, 2015 02:23 PM
Sep 1, 2015 03:16 PM
Walorus
Aug 18, 2015 01:39 PM
