Tire Wear
Old Mar 29, 2004 | 11:52 AM
MBailey's Avatar
Tire Wear
The inside tread of both back tires is wearing quicker than the outside. Is this a camber adjustment that needs to be made? How hard is this to do without making things worse?
Old Mar 29, 2004 | 12:42 PM
OKHJOON190's Avatar
OKHJOON190 is infamous around these parts
sounds like you have too much pressure in your tires ... i had the same problem before
Old Mar 29, 2004 | 12:54 PM
OKHJOON190's Avatar
i read it wrong .. my mistake .. i read it as middle of tire ... yes it is definately the negative camber
Old Mar 29, 2004 | 03:55 PM
Joe Weinstein's Avatar
Now wait a minute... It may be a case of not going corners
fast enough!
Joe
Old Mar 29, 2004 | 08:30 PM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
fast enough!
Joe
Exactly! Need to do more twisty, and less straight-line, driving.
Old Mar 29, 2004 | 10:00 PM
ebaker's Avatar
ebaker is infamous around these parts
The standard factory alignment has negative rear camber. More wear on the inside is normal on a turbo.
PAULUNM
14
May 27, 2016 06:54 AM
manny5
Feb 9, 2016 11:54 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Nikg
Sep 21, 2015 10:32 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
