Track Camera Mount question....
Old May 12, 2007 | 11:28 AM
ccayer's Avatar
ccayer is infamous around these parts
So for you guys that track your cars, what camera do you use? I have the I/O Port Racing mount and just bought a new Canon HV20 Camera and I'm less than happy with the results. The vibration is horrible.
Yes I have image stabilization on... mucked with the AF settings you name it... still looks horrible. Curious what camera you guys are using and any help that can be provided with the setup.
My setup in car is on the Techquipment bar with cross brace. As for settings on the camera... every damn thing you can thing of. Even called Canon and they were less than helpful....
Thanks in advance,
Old May 12, 2007 | 12:30 PM
GR996TT's Avatar
GR996TT is infamous around these parts
Thanks in advance,
I've used a number of compact Sonys with the same mount and the video is smooth.
I considered buying a HV20 but due to picture quality issues like you described (when used as a helmetcam for instance) I decided not to get one. From what I have been able to find online, the issue is with the floating lens element that Canon uses for image stabilization.
http://dvinfo.net/conf/showpost.php?...15&postcount=7
Old May 12, 2007 | 04:40 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
I've used a seperate (and small) RaceCase cam for years (roll bar)......along with seperate corder mounted on floor in back........works for me.
Old May 12, 2007 | 05:28 PM
manalex's Avatar
manalex is infamous around these parts
Here's the one I use.
http://cgi.ebay.com/Camera-Window-Mount-for-Car-CCTV-LCD-TV-CAMCORDER-3lbs_W0QQitemZ140103815465QQihZ004QQcategoryZ3325Q QrdZ1QQcmdZViewItem
I also bought a lipstick cam and mic, affixed it to the mount and stuck it to the windshield. The lipstick cam is then connected to your camcorder which you can secure anywhere. With me, that's behind the seat. The effect is that you have a much smaller mass on the windshield than you would with a camcorder. Not sure if this is allowed on all events, but the DEs I've done did not have a problem with it.
Old May 13, 2007 | 12:16 AM
ccayer's Avatar
Thanks guys, this POS will be going back tomorrow in place of a Sony device. I should have went that way from the beginning.
Jul 29, 2019 11:13 AM
alwaysbored786
Apr 19, 2016 05:51 AM
nlakind
Nov 6, 2015 10:15 AM
RallyBird
Oct 7, 2015 01:20 PM
pwdrhound
Aug 20, 2015 05:54 AM
