Check Engine Light...
Old May 16, 2007 | 08:34 PM
FlyingLow's Avatar
FlyingLow is infamous around these parts
I still think you should get some software. You're missing all the fun!!! OK, well not all the fun, how about most of the fun!
Old May 16, 2007 | 10:43 PM
Turbo Fanatic's Avatar
Does it give a "cat efficiency error" on one or both banks?
You may have a bad check valve this causes a rich condition and overloads your cats. Or need new cats under warranty.
Software won't fix your issues unless you go with something like FVD which disables the cat reading function...
Old May 17, 2007 | 06:58 AM
OneFasTT997's Avatar
OneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud of
I would but I'm under warranty. No way am I willing to risk losing that with some of the repairs I have already had!
Thanks for the info! I will get the code from the dealer today and see which it is. If it is one bank vs both what is the difference?
Old May 19, 2007 | 01:42 PM
It is both banks. I spoke with fabspeed and the cats are bad... Replacing the cats will make the used exhaust I bought more expensive than buying one new...
Old May 20, 2007 | 12:37 AM
ebaker's Avatar
ebaker is infamous around these parts
You might try cruising on the highway for some distance to see if the heat will clean the contaminants out of the cats.
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
