Damn wheels rubbing - People smarter than me help!
Old May 18, 2007 | 12:45 PM
digitekkz's Avatar
digitekkz is infamous around these parts
Originally Posted by Powell
Does it look like its hitting the outside of the tire? Like can you see little lines around the top of your tire that aren't suppose to be there lol.
my front tires does that, when i have it a slightly turn position. help
Old May 18, 2007 | 01:32 PM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
Originally Posted by club411
So would rolling the fenders help if it is rubbing on the inside of the wheel well and the on the outside. To be honest I am not sure where it is rubbing.
it's rubbing on the outside (not the inside) and yes rolling the fenders will fix it!
315width tires + TechArt 19" = rolling fenders!!
Old May 18, 2007 | 01:38 PM
club411's Avatar
club411 is a jewel in the roughclub411 is a jewel in the roughclub411 is a jewel in the roughclub411 is a jewel in the rough
But if it is rubbing on the inside then what?
Old May 18, 2007 | 02:39 PM
then u need to bend back the metal frame thats behind it.
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 18, 2007 | 05:35 PM
club411's Avatar
Anyone in the Chicago are that can diagnose and fix?
Old May 18, 2007 | 09:09 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
have your fenders rolled
Old May 18, 2007 | 09:17 PM
zona's Avatar
zona is infamous around these partszona is infamous around these parts
Club411,
Here's an idea-
  • remove all four wheels and inspect for rubbing
  • if nothing is noticable, coat the inside and outside of each tire with a heavy coat of some type of tire shine product
  • re-install wheels and drive to re-create rubbing condition
  • remove wheels and inspect for noticeable rubbing, the tires shine product will have rubbed off at the affected areas.
Just a thought!
BTW-Don't roll the fenders until your sure that is your issue! If the rears are rubbing on the wheel well, you will not be able to miss the rubbing on the tires!
-z
Old May 18, 2007 | 09:18 PM
dice996c4's Avatar
dice996c4 is infamous around these parts
have the alignment tucked in a bit and roll fenders... had the same setup on my C4S and Lucent did what they have to do and everything was magic..
Old May 18, 2007 | 09:20 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Doubtful is rubbing on the inside with that offset. Rubbing on the inside is easier to fix. Just get some spacers. Pull your wheels and look at the fender liners or wheel well lips. You'll see the rub marks. Rolling the lips is about $300. The only issue is will the paint crack. Sometime it cracks on the inside of the lip which is easy to brush touch because you won't see it. But sometimes it cracks on the outside of the lip meaning u have to respray the whole fender. No body shop will guarantee it will not crack. The 996 wheel wells are much thicker than the 993 and earlier cars. The 997 has the lips rolled at the factory.
Old May 18, 2007 | 09:23 PM
dice996c4's Avatar
It will only crack if the person doing it doesn't know what he's doing... I won't let a subprime shop do it.. Trust me.. I learned this the hard way... If you are in LA, don't let Speed Gallery do it... They use a hammer on mine... WTF ?!?!?
Old May 18, 2007 | 09:25 PM
dice996c4's Avatar
Club.. If you are tired of your wheels.. let me know.. Mine doesn't rub... and will not rub for sure... Love your TA
Old May 18, 2007 | 09:50 PM
club411's Avatar
you can see that there is about 2 inches of space
Old May 18, 2007 | 09:59 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
I have like 3" or so (I'm still stock ride height) and I hit my outside of the wheel on my fenders. I really need to get mine rolled. I already have the GT2 alignment and it helped, but still hits on any medium sized bumps even at like 15mph.
Old May 18, 2007 | 10:03 PM
lei's Avatar
lei
lei is infamous around these parts
thats strange, my friend had 19" TA the same as yours w/ 315's also.. didnt look anything like that.. are you sure you have the right offsets??? looks like its sticking out too much..
Old May 18, 2007 | 10:12 PM
Powell's Avatar
I wish mine was the fact that I had 315s, but I have 305 PS2s :-\
