Damn wheels rubbing - People smarter than me help!
19" techart gts on a 03 TT w x73. When I hit a big dip or bump the wheels rub - which wheel to be exact ..not sure
How can i fix? Is there a way to hike the car up an inch or so?
try an alignment first before you go crazy. IT IS TECHART. I really dont think they would design them so aggressive they would rub. but techart wheel owners would know better then I. I suggest alignment. GL
Suman
Suman
Does it look like its hitting the outside of the tire? Like can you see little lines around the top of your tire that aren't suppose to be there lol.
Club411,
The techart wheels for a 996tt have a 25mm offset (really, really agressive). No other company makes this offest/width/diameter combination 1 piece wheel! These wheels extend 1/4" further out that OEM GT2 wheels. Most people running GT2 wheels on a lowered car require rolling the fenders. So running 19x11/ET25 Techarts on a lowered 996tt, you will possibly have to roll the fenders and/or raise the rear and/or run more negative camber than stock.
-z
-z
Its not the wheel(12") or tire(315) widths that causes the issue. Its the offset. Most companies limit the offsets to 30 to 45mm. Don't know why TECHART choose an ET of 25mm.
-z
-z
Originally Posted by evo911
i hope i dont have problems, i just got Iforged Variant 19x12 315/25/19 lowered but guy before me said he rolled his for the (techarts) what a coincidence lol
it's your rear tires hitting the fenders... i have the same issue. get the rear fenders rolled.. should cost you approx $300 done professionally!
you should see pieces of rubber missing along the edge of your tire... and smell burnt rubber when you hit!
