OEM SSK/B&M SSK - adjustment question
Old May 25, 2007 | 01:18 PM
notquitefob's Avatar
notquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud of
Hello,
Do Porsche or B&M make an attachment clip like the one used to adjust the shifter cable on the stock shifter? It's like a clip that goes onto the shift base and allows you to center the shifter with the cables detached.
I noticed that I'm having slight problems going into certain gears, mainly 1 and 2, and I think my shifter may need some cable adjustment. I took it apart but the adjustment clip does NOT fit the Porsche SSK, only the stock shifter. I'm guess it'd be the same with the B&M.
any ideas? I would feel better using some sort of alignment tool rather than me just messing with it.
Old May 25, 2007 | 02:32 PM
wross996TT's Avatar
No such tool for B&M. I had my indy adjust it from the start and no problems at all....
Old May 25, 2007 | 05:40 PM
talked to eric@bumperplug. super helpful guy, he said i can always drive with teh center console off and simply adjust it. I'm looking more of a standard way of doing things.
do most people adjust it manually with the SSK ? or is there a standard for adjustment? I really don't want to take that center console apart AGAIN. Took it apart once for ebrake, once for SSK and once more for shift ****.
any ideas guys ?
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
Aug 19, 2015 06:35 PM
