service
Old May 26, 2007 | 02:36 PM
OCTurbo's Avatar
OCTurbo is infamous around these parts
service
I don't have a service manual for my 2003 99tt. I was told that the only service needed other than oil changes is at 30k and 60k miles. My car was at the dealership today for a stereo issue and they told me that i needed routine service at 15k mi (my car has 23k mi now). Is this true and do most of you get this done?
I'm getting a giac flash with flashloader and dv's next week. I'm ready for the fun factor to increase again.
Old May 26, 2007 | 02:51 PM
ard's Avatar
ard
I've been trying to find a link or pdf that lists the manufacturers minimum recommended maintenance for the 996TTs.... most often the dealer 'over-recommends' these 'servce packages' that are little more than an excuse to bend you over and extract many hundreds of dollars from you.
A
Old May 26, 2007 | 03:10 PM
19000rpm's Avatar
19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute
15,000 , a whole bunch of checks and an oil change. The Major service is at 30,000 is changing plugs and air filter out, which isn’t major at all in my book. Just keep track of your fluids and brakes
  • Required Every 15000 miles
    • Change Engine Oil and Filter
    • Engine: Visual inspection for leaks.
    • Cooling and Heating System: Check for leaks.
    • Coolant Hoses: Check condition and tighten connections
    • Radiator: Visual inspection for external fouling.
    • Coolant (antifreeze): Check level and antifreeze content.
    • Crankcase Ventilation: Check tightness of hose connections.
    • Intake Air: Check hoses, lines, and connections for tightness.
    • Brake Pedal: Check play of brake pedal and adjust if necessary
    • Brake Hoses and Lines: Visual Inspection for leaks, damage, and corrosion.
    • Check brake fluid level and top off if necessary.
    • Brake System: Visual inspection of brake pads and discs to check for wear
    • Clutch: Check play and adjust if necessary.
    • Clutch Plate: Check for wear.
    • Hydraulic Clutch Actuator: Visual inspection for leaks.
    • Steering Gear: Check screw connections for tightness. Visual inspection of the bellows for damage.
    • Tie Rod Links: Check play, tightness, and dust caps.
    • Power Assisted Steering: Visual inspection for leaks, check fluid level and top off if necessary.
    • Ball Joints: Visual inspection of dust caps for damage.
    • Wishbone: Check screw connections for tightness.
    • Front Wheel Bearings: Check play and adjust if necessary.
    • Rear Wheel Bearings: Check play and adjust if necessary.
    • Lubricate clutch release lever and secondary spring.
    • Manual Transmission: Visual Inspection for leaks, check oil level, and top off if necessary.
    • Automatic Transmission: Check fluid level and top off if necessary.
    • Drive Shafts: Visual inspection of sleeves for leaks and damage.
    • Exhaust System: Visual inspection of the exhaust system for leaks and damage. Check screw connections for tightness and attachment
    • Tires: Check condition and correct tire pressure.
    • Door Arrester (latch mechanism): Check operation and lubricate.
    • Door Hinges: Lubricate.
    • Check Door , Engine Hood locks and safety hooks on front hood for tightness and function.
    • Seals for doors, hood, and roof: Remove abraded rubber, apply suitable agent to seals.
    • Check Operation of vehicle lighting.
    • All headlights: Check setting and adjust if necessary.
    • Horn: Check operation.
    • Retractable Headlights: Lubricate rods.
    • Throttle Actuator: Check for smooth running.
    • Windshield Washer System: Check function, check fluid level, and nozzle setting and adjust if necessary.
    • Headlight Washer: Check operation, fluid level, and nozzle setting and adjust if necessary.
    • Battery: Check fluid level and top off if necessary.
    • Check operation of all electrical control equipment and optional extras.
Heater, ventilation, and air conditioner blower: check operation.
Old May 26, 2007 | 03:12 PM
jamie's Avatar
Old May 26, 2007 | 03:14 PM
slant911's Avatar
slant911 is infamous around these parts
Check this link for a complete listing of the recomended maintenance.
http://www.renntech.org/forums/index...=maint_menu_tt
Old May 28, 2007 | 11:11 PM
ko23's Avatar
ko23 is infamous around these parts
Even the service at 30K and 60K are pretty routine in my opinion. Nothing really major.
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
