Life begins at 213 mph in AdamT's RUF Rturbo
Originally Posted by winnigt2
Attachment 47777
nice video
but you dont need a ruf to drive fast
you dont need more as 1 bar turbo pressure
this speed was done with serial muffler, serial turbo k24
nice video
But man your speedo is quite a bit out, shows your at 6900rpm= 198mph (speedo is showing 327= 215mph) if you are running standard wheels, and also im assuming the GT2 has the same final drive as the turbo?
Where abouts in germany are you? Would be good to meet up and compare a GT2 against r turbo on the autobahn,
best,
adam
Originally Posted by AdamT
Nice pic,
best,
adam
best,
adam
gt2 have rear wheels with more radius....standard turbo goes by 322km/h and 6750 rpm in rev limiter and standard gt2 goes 334 and 6750 in rev limiter so you can go with rev limit over 7050 higher than a turbo with 7150 rpm . standard turbo shows on speedo only 341 km/h at 7150rpm and that is for the engine hard enough for a longer distance.
Nice pic,
best,
adam
best,
adam
i am near frankfurt
Our car which redlines at 7100rpm will do 331kmh real speed, We use Michelin Cups on turbo wheels. I dont understand how a GT2 will achieve 334 at 6750rpm, I think your confusing radius with width, the GT2 has slightly wider wheels than the turbo (can run 315s in the rear, instead of 295s) but i dont think that will have any effect on the top speed?
best,
adam
Do you mean on the speedo? Because i dont think a stock turbo will get near 322kmh, perhaps 310 down a hill and with a strong tail wind.
best,
adam
best,
adam
the speedo can show only 348 , more isnt possible to show with the oem speedo
more radius = more meters per second and more km/h per our....
