Boost controller
Old Jun 1, 2007 | 05:16 PM
bluetosman's Avatar
bluetosman is a splendid one to beholdbluetosman is a splendid one to beholdbluetosman is a splendid one to beholdbluetosman is a splendid one to beholdbluetosman is a splendid one to beholdbluetosman is a splendid one to beholdbluetosman is a splendid one to behold
Boost controller
i need help on how to install Greddy manual boost controller.
thanks in advance.
Old Jun 1, 2007 | 06:30 PM
andyk79's Avatar
andyk79 is infamous around these parts
Where did you get you greddy boost controller?
Old Jun 1, 2007 | 06:33 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Greddy Profec B Spec II install in 996tt
Disconnect the factory vacuum lines from the wastegate solenoid.
Connect the Greddy NO port to the port off of the Y-Pipe just outside of the throttle body.
The COM port should go to the line that runs up over the manifold and T's off to the w/g actuators.
The NC port should go to the line that runs towards the drivers side of the car, then to the rubber pipe that holds the diverter valves.
Be sure that all the little red plugs are out of the solenoid!
Tee off the fuel pressure regulator vacuum line and route the hose along with the w/g controller harness.
Route the wiring harness forwards, just to the left of the oil tank, tie wrap the harness to the factory hose routings along the way. In the tunnel, just in front of the grommet that the shifter/ebrake cables go through, there's a 1" diameter grommet. You can route the harness up through there.
You can place the controller in the center compartment where your right elbow would go, leaving about 14-16" of cable to pull it out and adjust it, then put it away when done. But you can mount it where ever you'd like. You will need extra wire and hose if you want to mount it on the front console like this:
The hot/ground for the w/g controller can be taken from the power window switches if you use the glove box mount. In the front mount you can use a "key-on" fuse from the fuse box near your left leg when seated in the car. Be sure the source you use is a full 12v and ground.
credit to: TK
Old Jun 1, 2007 | 06:47 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Why did you go with a manual over an electronic unit?
Old Jun 1, 2007 | 07:00 PM
I think he meant electric.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 1, 2007 | 07:08 PM
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
would this be safe to run on an allready chipped car?
how much more boost could you theoretically run on perhaps some race fuel?
Old Jun 2, 2007 | 07:37 AM
bluetosman's Avatar
thank you John
credit to: TK
NC 996TT
Mar 23, 2023 06:19 AM
davetherave
Bentley
Sep 11, 2015 04:15 AM
