Europipe has arrived !!
Also fitted the X73 Suspension package including Solid motor mounts. Was expecting the X73 package to lower the car 20mm. However car only lowered 5mm front & rear from RoW spec. Very happy with feel of the car, very firm & direct. The Europipe Loud exhaust sounds great....every 996TT should have one!! It took two days to fit the X73 kit, Europipe, UMW Forge BOV's, OEM Short shifter, CF Shifter & H'Brake, Plugs including full service. Next project to follow (a few months time) UMW LWFW / Sach's Clutch.
http://www.europipe.be/1024.html
I installed the EP Stg II Q. I chose the Qs over the Ls because of an already self induced moderate earing loss from many years of motorcycles, convertibles, and loud exhausts - and I wish I was kidding. From Europipes spec sheet the performance between the two should be nearly, if not exactly, identicle. The Qs are load enough for my neighbors, and by the time they break-in and get louder, they will be used to it. The sound is fuller/richer at idle, and grin inducing when under full boost.
sdg1871
Sep 29, 2015 09:30 AM
