I think my Clutch is dead! :(
If you use the GT3RS clutch and flywheel, do you have to flash the motronic to compensate for the lighter flywheel. On the 993's the engine would die when you came off throttle to a stop as the motronic expected a dual mass fly wheel to keep the motor spinning as it switched to the idle circuit.
Originally Posted by skiboard06
with the gt3rs flywheel does it chatter at all when idling?
I had the REVO stage 2 software "tweeked"and problem solved. I think what you mention was the problem.
I dont think all cars will see this however so no mass panic. Also I think the fact that my car has straight pipes off the turbos also had something to do with it.
ECS Tuning - BMW
Sep 16, 2015 07:20 AM
ECS Tuning - VW
Sep 9, 2015 03:11 PM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
