EVOMS 9.67 @ 149.86 - The Video -- Language Advisory - Sorry
Thanks Stephen, Dan,
Interesting to see what can be done with little time. From this I conclude that power is not as important as weight and good driving for these cars to be up there.
3000 lbs with Dan inside must be around the numbers posted earlier (close to 2800 lbs).
As far as gearing is concerned, what explains having done 150mph in 4 gears is therefore the higher rev limiter (8K+ RPMS). I am guessing there is also some work done on the valvetrain side to withstand this.
Smart setup!
Smart setup!
Smart setup!
Smart setup!
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Todd, I hear the rev limiter a bit after seeing the numbers on the screen
Maybe you had fatter tires (taller)..
Not that it matters though, other than regarding the stock valvetrain reliability for a customer car.
Maybe you had fatter tires (taller)..Not that it matters though, other than regarding the stock valvetrain reliability for a customer car.
Originally Posted by MARKSKI
Craig,
this has been a mystery to me becasue a truck stop scale showed 3080 lbs. and Todd K ( when he corner balanced the car) resulted in 3280 lbs.( no driver)
I only took out the carpets with side panels, put in gt3 seats, and took off front and rear bumpers...( Im also RWD). I put back front and rar sway bars and our axles added another 60 lbs.
The interiror is at most 120 lbs. bumpers I believe 10 lbs each plus the bumperettes about 6 lbs each. GT3 seats saved me maybe 40 lbs.
all this was on stock rims and stock brakes.
I am confident that my car weighs 3300lbs or more.
I have stock gears.
But in this game it does not matter nor is it an excuse. I know it is a good comparison between these 2 cars. we cut a 1.74 60ft. due to the axle issue... Todd cut a 1.59 60( from what I was told). that difference is about .3 seconds in ET. if true, assuming my calculations are correct, the extra 300 lbs is another .3 sec in ET. We ran the car at 19 PSI and shifter at 7500 rpms.
I am being hosest...nor am I looking for excuses... this is great info we all are sharing and in this case it is good to compare our cars.
Kudos to Evoms for a job well executed.
Mark
I have stock gears.
Mark
I had no interior carpet nor door panels, bumper supports and 1 x GT3 seat with Porsche roll bar. My headliner and sunroof were still in the car as I want to drive and enjoy my car with the interior back in it next week
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Todd,
I also left my roof lining in place... I also have the same roll bar. we ran 2 seats. I didnt want to take out the AC and the power streering... Im told thats another 150 lbs. I have JIC suspension with stock sway bars back in.
we ran some light 17s in the back but normal 993tt front rims.
Ill give it a whirl one more time... hopefully the clutch and the axles stay together....
best,
mark
best,
mark
2001 996TT 3.6L and stock ECU
I didnt want to take out the AC and the power streering... Im told thats another 150 lbs. ....
best,
mark
best,
mark
Do it Mark, you deserve it. I would not have done this now if it wasnt for you. Your attempts and being on the edge drove us to this point. I appreciate your attempts and for pushing the envelope. It is all good and I am glad we push these cars hard and we can enjoy them and have them do things that they were not intended to do. Let me know if you need some axles. I and a few others have put them through hell. You will not break them. Lets talk next week. Todd
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Originally Posted by WOODTSTER
Craig,
the biggest factor in running a GT800 in the 9's would be HOW MUCH weight
you can strip out of the car. JoeTwint's GT800 should be/is a good example
of that; very strong car (his), very good driver (him), good track (hell he lives in the mecca of good tracks), but his car is not light enough.
The silver test mule (yes "worlds quickest" 996TT!!) must have had
no interior I am guessing. I would think the door panels were gone, carpet,
passenger seat, etc, etc. This would not be considered a "fully equipped"
GT800 right?
MK
GT800 right?
MK
Originally Posted by Todd @ EVO
Guys,
Thank you for all of the support. I hate to pop in and pop out like this but I limited time to be on the computer until I get back to the office Monday in AZ. I am spending some much needed "Family" time and I promised my wife that I would not spend endless hours on the computer. I have not read through all of this yet to answer all of the questions but here are a few that I saw:
Gearing: 100% Stock 996TT Gearing
Weight: ~3000 pounds with me in the car. I will confirm and weigh the car when I get it back to the shop - IT IS NOT 2400 pounds like the speculations.
Motor Internals: ARP head studs, EVO head gaskets, Carrillo rods, GT3 oil pump. --(Stock heads/cams/pistons)--
Engine Components: 100% off the shelf EVO GT800 tuning system with higher rev limit - Bosch ECU - GIAC Tuned. ~ 25 PSI boost
Power: ~750 RWHP. I am not trying to be vague, however we only had time to put it on the dyno for a few pulls to check the AFR's and that was it. I will dyno it and post the results when I get the car back and on the dyno again.
Please keep in mind that this was a last minute hair brained idea that started out as a conversation with Joetwint and by the end of the conversation it was a plan that had no real planning put into it. I committed to have the cars in NY 2 weeks from when I hung up the phone. Our 996TT needed an engine and transmission and complete tuning system.
When I told John Bray (EVO's master tech) the plan, he looked at me and had one word: DONE! He walked away from me after that one word and started building an engine. Done? I was not sure what he meant but that translated into: I will get it done no matter what. I will not only have the 996TT ready but I will have the 997TT ready as well. John likes challenges and this one was no different than all the other challenges he has endured throughout the long affair with our 996TT. He and this car have a long history and he knew exactly what it needed to get the job done I have to go but I will try and read through the rest of the questions and get them answered when I can before Monday.
Guys,
SNIP
SNIP
Thank you VERY much for the frankness, Todd...and once again, congratulations on the setting the new bar for our cars!
Scott
Craig,
...but I also have 15 lbs of RUF spacers and a 27 lb Tequipment roll bar installed.
I will probably remove the passenger seat when I go to the track to mimic the weight saved with GT3 seats (which I might install)...so that would put me at around 3,500 lbs with me in the car on the dragstrip.
Originally Posted by 01TT
How much does the Camaro weigh?
Originally Posted by Powell
~3100 with me in the car and a 15lb bottle. The car has a 3 gallon fuel cell for the motor and 1 gallon for nitrous. So I don't have fuel to weigh me down
