NHRA rules for street cars.
thats the one
Just in case these people are the Official NHRA Sport Compact Drag Racing School
www.driven2win.net
www.driven2win.net
I'm going to be getting my NHRA license passes done this Fall. You must renew you license on a yearly basis or it will expire. Here is what I must do to get the license:
- Come to the track in a vehicle that is NHRA legal to 8.50, For my Dodge, this includes, full cage that has been NHRA certified (swing out door bars are legal to 8.50), scatter shield on the tranny (this prevents the gears from slicing through the floor (and you) if the tranny grenades), window net (this prevents your arms from flopping out and being crushed in a rollover), kill switch on the rear of the vehicle (in case you're wrecked and they need to kill all power to the car), 5 point harnesses, helmet, neck collar, fire rated jacket, pants and gloves.
- A full physical (this is to show that you won't drop dead when the car crosses the traps a 160+)
- Blindfold Test (you must be able to shut off and escape from the vehicle while blindfolded in 15 seconds)
- 6 passes...2 60' passes, 2 1/8 mile passes and 2 full 1/4 miles passes (both must be under 10 seconds and within a few 10ths of each other.
Originally Posted by Powell
I don't have my license yet. I've made enough passes to get mine but I never did actually get it. The guy that does the certification in Houston goes around Houston to do his.
did they banish you from the track?
Originally Posted by cjv
Kenny,
Can you explain what 4.4 is or entails?
If you use CM then you need to have the tech done before you paint it.
Originally Posted by RennTechV12
You went 8.90 with no license
Normally she would throw anyone out. I've seen it before. But she just smiles and hands me my slip. I have my fire jacket/pants/etc.. on so I think that is enough for her. lol. I've made friends with all the people at the track so it does help a little.
The lady loves me
Guys, the safety regulations are there because in days gone by (when there were no rules or few rules) people out to have a goo time got hurt or killed.
Don't think it's smart to sidestep the NHRA rulebook on safety. It's there to save your life.
Going by these rules my car ( with the tequipment bar and harnesses)should be legit to 10.00.The E-Town track official told us we needed a door bar for anything under 11.50,which I couldn't understand because I had run last year (10's)that way.
Does the bar need to be welded in?Wouldn't door bars make it a cage and not a bar which would be good to 8.50?
Originally Posted by MrBlonde
Tequipment is not up to NHRA standards. The rule book has the minimum tube dimensions and shows how the cage must be welded into the car.
I was all proud the first time I showed up at the strip with my NHRA certified cage. No more getting yelled at or told to slow it down or park it. So when I tell the tech guy that the car will run 9s, the first thing he says is "lemme see yer license." It's like they can read your mind.
So anyway, I got one.
Jeff
Jeff
Jeff
Jeff
It makes things so much easier when you can run without worrying about getting kicked out.
