EVO ShiftLink
Old Apr 7, 2004 | 11:17 PM
KPV's Avatar
KPV
It sure does to me.
Old Apr 8, 2004 | 12:04 AM
Tool Pants's Avatar
Tool Pants is infamous around these parts
I would put in the shift link in first while the oem shift lever is still in place and you can still use the locking bridge. Then there is no hit or miss adjustment needed when you install the B&M.
Old Apr 8, 2004 | 06:27 AM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
Originally posted by rockitman
I wunder if it's just a matter of matching up the length of the stock one you pull out with the billet one??? Makes sense, doesn't it???
That is exactly what I did. I made the link the same approx. length as the plastic coupler. I then installed the cable to the point that I had it marked.
Perhaps I was very lucky, because it all went back together correctly the first time. The N position is right in middle of the 3-4 gate and I have had no problems getting into 1 or R.
Old Apr 8, 2004 | 07:39 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
I need to adjust mine to the left just a hair
Are you talking about adjusting the hex bolt at the front? That's the only "left" adjustment available I can see.
Old Apr 8, 2004 | 08:26 AM
TCM's Avatar
TCM
TCM is infamous around these parts
Dock:
We ended up adjusting the shift line cable to compensate for the Evo Shiftlink reduction if I remember correctly. Once you have the console off, it is not a big deal, just a bit time consuming. I have yet to figure out why Evo used such small lock screws on the end of their piece (you can barely see them). Good luck with the install.
Old Apr 8, 2004 | 09:19 AM
Does the green plastic plate at the bottom of the shift console have to be remain?
I broke one of the tabs taking it off.
Seems there would be more clearance for the ShiftLink with it out.
Old Apr 8, 2004 | 10:40 AM
Dr. T's Avatar
Dr. T is infamous around these parts
Discard the green plastic plate.
Old Apr 8, 2004 | 10:51 AM
dilly's Avatar
dilly is infamous around these parts
I had the B&M SSK and the Evo shiftlink sitting in my garage since Christmas and just barely installed it the other day. It took me and a buddy a couple of hours to install and was easier than we thought. The Evo shiftlink didn't come with any instructions so I was worried it wouldn't go in right, we just macthed up the length like Sloth did to the old plastic one. As for cutting the stock bushings out, someones suggestion for using dykes worked great. Kind of disconcerting to be cutting into and destroying the old bushing though.
Can't tell you how much I like the new shifter better than the old one. It does take more effort but much more postive and shorter shifts.
Old Apr 8, 2004 | 11:07 AM
Porsche's Short Shifter installation instructions direct the Tech. to use a chisel to tap off the bushing tabs. That's what I used and I had both bushings out within 60 seconds. The only way to go IMHO.
Old Apr 8, 2004 | 11:13 AM
I'm looking forward to that because the OEM shifter takes too little effort.
Old Apr 8, 2004 | 11:24 AM
NelsonF's Avatar
NelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to behold
Don't forget to engage reverse as part of your adjustment testing(Make sure it's actually engaged). Mine did not really engage on initial setup after initial manual testing. I had to go back to adjust the cable position after I realized I could not back my car out of the garage. Works great now and I'm glad I did the whole mod. The EVO linkage combined with the B&M unit creates a very positive and solid feel.
Old Apr 8, 2004 | 11:30 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
If you are using the stock shifter and just installing the billet linkage piece...How do you take the stock plastic one off??? Do the cables pop or pull out of the bushing or do you cut it out??? Confused...
Old Apr 8, 2004 | 12:29 PM
rockitman's Avatar
Thanks Ruiner...It's much clearer now... :-)
Old Apr 8, 2004 | 02:49 PM
rockitman's Avatar
A more specific thread regarding the shiftlink install issues I started on renntech, fyi. Thank you Tool Pants!!!!
http://www.renntech.org/forums/index...t=0&#entry7511
Old Apr 8, 2004 | 06:14 PM
Rockitman - The B&M site has the complete installation instructions, with pictures.
