BBK fitting problem
Old Jun 21, 2007 | 04:29 PM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
BBK fitting problem
I just bought a front BBK from Manthey-Racing in Germany for a 996 Turbo. It came with GT2/GT3-Cup 6-piston calibers and 350mm GT2
discs. The problem is that the fitment with the stock hub isn't correct. The disc isn't centered between the pistons.
I'd like to know if there are some kind of replacement discs which have been machined to fit without the need to adjust the calibers?
At the moment one option is to custom-made both the calipers and brake pads for GT2 brake disks so they can be used on normal 996TT front hubs, but that doesn't sound wise!
Any idea are the disks sold by EVOMS just OEM GT2 (they won't fit!) or something else that would fit without a hassle!
(I'm talking about 350 mm 6-piston kit).
Thanks for any info!
Old Jun 27, 2007 | 09:01 AM
Kaizu's Avatar
Any ideas? EVOMS hasn't answered. It seems that doing some custom-work is needed...
Old Jun 27, 2007 | 12:17 PM
WOODTSTER's Avatar
Kaizu:
Is the Caliper a Brembo?
If so find the Brembo distributor in your country and call them.
I the US of A it is Race Techonologies
Marty Kaye
Old Jun 27, 2007 | 12:32 PM
PV996TT's Avatar
PV996TT is infamous around these parts
KAIZU
You have to do som machining to the hub. I have made a jig for that so send me an e-mail at peter@ruf.se and I will try to help you. I am located in Sweden.
Peter
mikerosi
Dec 6, 2018 06:23 PM
97GtsMonster
Nov 17, 2015 12:38 PM
nlakind
Nov 6, 2015 10:15 AM
LiquidElephant
Aug 27, 2015 06:17 PM
osj911
Aug 26, 2015 06:41 PM
