How to Dyno 911TT?
Old Jun 21, 2007 | 06:51 PM
wirx's Avatar
wirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud of
How to Dyno 911TT?
Hi
Yesterday i went to Finlant to http://www.amworks.com/eng/index.htm (near here isn't very much 4wd dynos), beginning all work fine and we make a soft test run/tires warm up, then mechanic sprays litle glue in to tires and we are ready to get numbers, but front wheels aren't any more running fast, mybe 5km/h, when rear ones are 50km/h....in test run front ones seems to spin as fast, as rear ones...
We wait ~20 minutes and tried again...same thing...front wheels aren't moving...
So I get no dyno graph....
He had dynoed plenty 4wd audis, subarus, skylines, evos, etc ant porsche was first car, what doesn't give reading :s
Can anybody say what was reason why front wheels aren't spinning on 4wd dyno?
Old Jun 21, 2007 | 07:52 PM
turbo ZOU's Avatar
turbo ZOU is infamous around these parts
same here ! i try to dyno my two weeks ago ! same
Old Jun 21, 2007 | 08:39 PM
MidnighTT's Avatar
MidnighTT is infamous around these parts
I pulled the front drive shaft and dyno'd as a rear wheel drive car. Pulling the drive shaft is easy as long as you can get the car a foot or so off the ground.
Jeff
Old Jun 22, 2007 | 02:39 AM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
Same problem happened to me while trying to dyno. Gotta change the car to RWD for dynoing it seems...
By the way, when are you coming next time to Finland? Perhaps we should meet! There's some nice Turbos in Finland but of course it's a rare car...
Old Jun 22, 2007 | 03:10 PM
wirx's Avatar
So I need to convert then to rwd...
Kaizu I let u know, when I come to finland
thanks for replies!
Emre@Esmotor
Oct 19, 2015 12:06 PM
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
