Difficult shift from neutral to first...
Old Apr 13, 2004 | 09:42 AM
Joe Weinstein's Avatar
Hi all.
My problem is that my car will sometimes be very resistant
to shifting into first from neutral. It will even bedifficult to
shift into second too, but if I shift into third, I can then shift
into first as I want.
I have heard of various transmission gremlins being fixed,
after long periods of dealer denial, by lubricating some
transmission shaft. Is that my problem, or do I have syncro
problems?
thanks,
Joe
Old Apr 13, 2004 | 10:15 AM
KJM3's Avatar
KJM3 is infamous around these parts
It seems most manual cars have this problem (although to varying degrees).
In my Integra Type-R, sometimes I would get locked out of first totally. To get into 1st gear, I would have to go into 3rd gear first and then going into 1st gear would be no problem.
With my BMW M3, sometimes going into 1st gear is tough, but if I really force it, it'll go in. If I go into 3rd gear first and then try 1st gear again, it'll go in no problem.
Sometimes I think the gears get misaligned, so going into 3rd gear first must line them up perfectly.
I don't think there's any problem with your transmission at all.
Cheers,
KJ
Old Apr 13, 2004 | 10:53 AM
BCS996TT's Avatar
BCS996TT is infamous around these parts
Joe,
From what i've been told...this is normal. I too have the same issues. I posted a thread on this about a month ago and I believe the overall consensus was that it was normal.
Old Apr 13, 2004 | 11:44 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Joe - I don't have any problem at all shifting into any gear, from any gear, including heel-toeing to 1st at 15-20 mph.
Old Apr 13, 2004 | 11:46 AM
thanks dock. I know there's something wrong, and I'd
very much like to be able to change trouble-free into
first from neutral or second.
Joe
Old Apr 13, 2004 | 11:56 AM
Joe - Is your car still under warranty?
Old Apr 13, 2004 | 12:01 PM
not officially. (August '00), but it's got 7500 miles on it...
Old Apr 13, 2004 | 12:06 PM
I hope you get it all worked out.
Old Apr 13, 2004 | 12:11 PM
TCM's Avatar
TCM
TCM is infamous around these parts
This is normal in manual transmission cars. As stated above, your gears are just not perfectly lined up. By putting the car into another gear it will adjust the gears a bit so going into first in no longer an issue. I have had this in every manual car I have ever driven (Porsche, BMW, Corvette, etc). I would not worry about it.
Old Apr 13, 2004 | 03:20 PM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
not normal
If it was normal , all Porsches would do it.
Mine does not.
Maybe I'm not normal.
Old Apr 13, 2004 | 03:22 PM
The Porsche race shop I ask, said it's either a bit of residual
stick of the clutch, or syncro damage.
Old Apr 13, 2004 | 03:42 PM
RKS's Avatar
RKS
RKS is infamous around these parts
No problem here shifting to any gear. Hope your dealer takes a positive attitude towards investigation and warranty repair if necessary at that low mileage. Good luck.
Old Apr 13, 2004 | 04:30 PM
ebaker's Avatar
ebaker is infamous around these parts
There is a technical service bulletin on a lack of lubrication between the splines on the transmission input shaft and clutch disk. This causes the clutch to drag, or not stop spinning, so gear engagment is difficult. Also as KJM3 said it might be a normal misalignment of the gear teeth. I don't know how to check for clutch drag since all gears are synchronized including reverse. It seems like a dragging clutch would prematurely wear all the syncronizers.
Old Apr 13, 2004 | 06:26 PM
BCS996TT's Avatar
Joe,
Let us know what you find out. I believe your problem is more severe than mine, as a simple shift to 2nd back to 1st will solve my issues most if not all the time.
Old Apr 13, 2004 | 10:10 PM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
Joe, I sent a couple of guys my service invoice when I had a similar problem with my new 2003 Turbo. PM me your fax and I'll send you the same. This was discussed a week ago in detail and many people had the same problem, it is not normal and sounds like synchro wear caused by a manufacturer's defect like mine. MSINDI had the problem after only a couple hundred miles. Let me know I'll help as much as I can.
Lou
