Fuel line Q?
Originally Posted by roadsterdoc
What are you basing this on? 60lb injectors are used in the GT700 kits. Online fuel injector calculators will show them at about 70% duty cycle for 700 crank HP.
According to Ray Hall (If I remember correctly), hp = 10.87*lb/min of airflow. Assuming wheel horsepower is approximately 15% less than crank horsepower (maybe more in a Porsche) If you're making 590whp, that would be around 695 engine horsepower (using 15% loss) - with these numbers that is around 64lb/min of air.
I don't know what lambda/AFRs you all generally tune to, but given a lambda of .80 (11.76AFR) that would mean that your engine is consuming 5.44lb/min (326.53lb/hr) of fuel - divide that number by six and you need 54.4lb/hr through each of your injectors yeilding a 91 percent duty cycle...approximately of course.
On an 8 cylinder if you require 326.53lb/hr - that would mean you only need 40.82lb/hr out of each injector putting the duty cycle at approximately 68%.
adnanm3
Nov 22, 2023 02:43 AM
Emre@Esmotor
Sep 9, 2015 08:48 AM
albert@velosdesignwerks
Sep 3, 2015 11:11 PM
