Evo Adjustable Westgates Question
Old Jul 23, 2007 | 11:42 AM
benguss's Avatar
benguss is infamous around these parts
loctite after I resolve my overboost problem,
Old May 6, 2011 | 11:45 AM
Originally Posted by Billystang
ok 3 years later one of the westgates not working ,called Evoms and for 2 days waiting for a call
try to buy it online w/2 ccards and is not working
can anyone tell me if i can get westgates for k24-18g from someone else?
Thank you guys
Blouch
#TeamAIM
Old May 6, 2011 | 03:06 PM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
Originally Posted by benguss
thanx, reading now, trying to find out if it's another prob, cuz I've been doing the adjustment with bicycle pump and gage and can't find the sweet spot.
i have evo wastegastes and set them to open point 11psi, no problems with overboost.....
Old May 6, 2011 | 07:18 PM
johnspeed's Avatar
Hi,The most accurate way is getting a low PSI air supply with a low PSI gauge connected,,easy to make,.....Remove the vaccum lines from waste gates and the pump up the air,,SLOWLY,,and watch when the rod arms on the gates just start to open/move..Do both the same way...Usually with a non flashed car about 11 psi is max,crack point/opening point.......Good Luck
Old May 7, 2011 | 03:22 AM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
I used a little manual pump with a low reading gauge. Dave@EPL told me to set them to crack open at 13.5PSI and watch them while releasing the pressure from above 14psi to see little movement at 14 and nothing at 13psi.
I'm happy with the job I've done. It's been easier than I thought.
Old May 7, 2011 | 08:04 AM
johnspeed's Avatar
Yes,thats how I did mine also ...But we have a Flash,so we can go that PSI,,,,,,,,,,The OP said he had no flash.....Actually,I had to set my crack open point to 12.5 PSI due to overboosting in the cold weather.......
Old May 7, 2011 | 03:59 PM
winnigt2's Avatar
the bracket on the evo wastegate right side is not real good in fitment....i use the bracket from the original wastegate ....not easy to do, but the rod is better in line with this modification on the right side .....
Jul 29, 2019 11:13 AM
TrackOne
Aug 20, 2015 12:56 PM
Aug 19, 2015 06:35 PM
Wheel Experts
American Muscle
Aug 19, 2015 09:07 AM
Wheel Experts
Wheels/Tires
Aug 19, 2015 09:05 AM
