Corner Balance Important for Coilover Install?
Old Jul 11, 2007 | 07:08 PM
MidnighTT's Avatar
MidnighTT is infamous around these parts
So how good is good enough? After I installed my PSS9s I went in for an alignment and CB. The scales said I was at 49.93% LF-RR / 50.07% RF-LR with my hulked up mass ( ) in the driver seat. The error was 6 pounds, and the tech advised against messing with it, so we didn't.
Do y'all agree?
BTW, the car weighed a porky 3591 w/driver. It has exactly zero lightening mods.
Jeff
Old Jul 11, 2007 | 08:57 PM
Sonny's Avatar
Sonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud of
Yeah, don't mess with it,.
Old Jul 11, 2007 | 09:30 PM
Dub-U!'s Avatar
Dub-U! is infamous around these parts
Corner balancing finishes the car for sure, however, your car might look like it's not level. That can be a concern for somebody that drives on the street only.
Old Jul 11, 2007 | 10:13 PM
Joe Weinstein's Avatar
Originally Posted by roadsterdoc
Wow Joe, great job! So will you share with us your setup? I am forwarding the video to my Solo2 buddies that say rear engined Porsches are no good for autox.
Protrac single-adjustable racing gas shocks, lower stiffer coilover springs,
2.8 deg negative camber in front, 2.5 in the rear, Complete Custom
light-weight 9.5x18 front wheels, 11x18 rears. Advan Neova tires, (Kumho
710s for ASP), S-Car-Go CF intake, Upsolute tune for the k16, Europipe II,
light weight flywheel and stage 3 Evo clutch, Evo DVs, Evo hoses, Evo
quickshift. ERC racing unleaded. Race-technology AX22 data collection.
Advanced corner-balancing to optimize cornering sameness left and right
(ie: LF/LR = RF/RR). PSM turned off unless there's standing water.
For autocross I think the k16 is actually better than k24 or any others
because of instant boost for those long 2-second straights. If I had a
$ponsor I'd upgrade to the PCCB brakes and GT3 seats.
Joe
Old Jul 12, 2007 | 06:50 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Ditto all that's been said.
1.) install
2.) set desired ride height.....Porsche spec or yours
3.) set desired height front-rear, rake....Porsche spec or yours
4.) have adjustable DLs and CB
Jul 29, 2019 11:13 AM
MadWhip
Sep 3, 2015 02:04 PM
su_maverick
Aug 21, 2015 07:14 PM
