Excess Vibration from Engine?
Old Apr 17, 2004 | 08:02 AM
KJM3's Avatar
KJM3 is infamous around these parts
Originally posted by msindi
vibration of seats is normal...more noticeable if you have sports seats too
Yeah, the car I'm looking at has Sport Seats!
PHEW, what a relief!
Anyway, if all checks out fine, I'll be driving it by Tuesday/Wednesday!
- KJ
Old Apr 17, 2004 | 08:34 AM
sporters78's Avatar
sporters78 is infamous around these parts
vibration at idle with sport seats me too
Old Apr 17, 2004 | 08:51 AM
MKW's Avatar
MKW
MKW is infamous around these parts
Subtle passenger seat vibration at warm idle with mine also - that's the " motion " I referred to in prev post. A very rough idle or hunting could be misfiring from bad injector, bad plug etc. Have dealer hook up their tester to look for fault codes and history of type 2 ? wrong -gear -downshift overrevs to be sure it doesn't have a bent valve ! 2001s had a colder plug that occas fouled - they changed to hotter plug on Turbos in 2002 production.
Old Apr 17, 2004 | 09:58 AM
h20tt's Avatar
h20tt is infamous around these parts
Good point. If there is a bent exhaust valve from over rev, idle would be erratic, not a steady 780 RPM, just my $.02
Old Aug 27, 2010 | 06:04 PM
racegate's Avatar
racegate is infamous around these parts
Just wanted to bump this thread as to not start another one.
I have a vibration that can be felt at idle in my bone stock X50. Its noticeable, but not crazy. I can also see the pass seat vibrate when I look over. The RPM is STEADY at 780rpm, so the engine is not hunting. Could it be a worn mount? If I raise the engine RPM ever so slightly using the throttle, the vibration goes away. At speed its perfect.
Question is, why do some owners have an issue with this, and others dont?
Old Aug 27, 2010 | 08:21 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
The IMS or intermediate Shaft in these cars cause it to vibrate and some do alot and porsche says its fine. People with lightweight flywheels there cars rattle like a marble ina tin can (mine) its just the nature of the engine design and the IMS this is not a lexus.
now if you had SOLID mounts it would make this much worse, or mounts so worn they are metal to metal which is unlikely.
Old Aug 30, 2010 | 01:47 PM
Mr swed's Avatar
Mr swed is infamous around these parts
I had some vibrations that were visible in the passenger seat and it was related to the electric fans that blow air through the left and right side ac/condensers and the radiators. It was a missing balancing weight on the fan blade on one side. I disconnected the connector to the fan and the vibrations disappeared, changed the fan for a new one and haven’t had any vibrations sins
Old Aug 30, 2010 | 08:13 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
no vibs here
Old Aug 31, 2010 | 01:51 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
+1
Mine vibrates too
Old Sep 1, 2010 | 08:41 AM
Tireboi's Avatar
Tireboi is infamous around these parts
could be normal mine does the same
PelicanParts.com
BMW Vendor Classifieds
Aug 25, 2015 03:55 PM
PelicanParts.com
Aug 25, 2015 03:43 PM
PelicanParts.com
Aug 25, 2015 03:35 PM
PelicanParts.com
996 Vendor Classifieds
Aug 25, 2015 03:31 PM
