Tuner in Texas
Old Jul 29, 2007 | 12:20 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Originally Posted by drjoe
I was told they are new to Houston, but have a large more established facility in Mexico. They are the only ones licensed to flash the EVO software in Houston (I know because I tried looking around) and mainly install bolt-ons. For the the newer p-cars, I'm pretty sure most owners just want bolt-on and flashes/ suspension (which I would send to a porsche race shop such as tracktime performance for coilovers,etc and cornerbalance-alignment ). I think Carboy (imports) and MTI (domestics) have not done newer Porsches. If you're looking for overboring/ sleeving, there are some machine shops in houston that can do that and assemble the long block at the same time (but they probably won't/ can't dyno tune these porsches in Houston; because there isn't a big market plus the amount $$$ it would cost). Tuning on the other hand I would ship to Proto.
Yes, I believe Akram Motor Sports and Proto are working close together. I had AMS do my build and fine tune by Proto and Lewell Racing (in Houston). Protomotive tuning can be done locally, hence no need to ship your car! But it is expensive. The base programe is 3k; however, to ship your car round trip can cost 1,500. As far as costumer satisfaction, I would rate Protomotive an A+ and AMS just as high. I have had many misfortunes in the past and I am very happy to encounter two very professional individuals.
Cheers
Robert
Old Jul 29, 2007 | 02:21 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
My observations-
I think the closest hardcore 911 tuner to us is going to be Imagine Auto in Kansas, and Ruf AC in Dallas. I think the RUF stuff is waay overpriced. Stephen at Imagine works directly with Garret at GIAC. ProTechnik and Viking Motors have a good amount experience if you want to go Motec or other stand alone. Carboy can do piggybacks on virtually anything.
Suspension wise it would be hard to overlook Don Irby at Porsche West Houston. The guy has been setting up PCA club racers for perhaps 20 or so years. For people who have done lowering springs he can send off your Bilsteins for a rebuild + piston shortening + matched revalving to Bilstein in California. Usually takes 2 weeks and is about $500 for a set of 4. Sam at ProTechnik is also no slouch. Sam can fab a cage as well, but his dyno sux and the wideband never works.
For machine work, I have heard of a great machine shop in San Antonio (forget the name) which is very reasonable on the floating cylinder sleeve blocks. Lindsey in Oklahoma can also do blocks and has a great reputation on heads. If you port your heads PolyDyn in NW Houston has a great temp coating for the exhaust ports and piston tops, as well as a friction coat for the piston skirts and crank arms. They of course also do header and turbine coatings and their turn around is much much faster than Swain, Airborne, etc.
Texas Turbos here in town off 290 and Mangum does turbo rebuilds for $275 in about 2 days. They are one of the largest rebuilders in the country, and have a limitless selection of Garret and Turbonetics, as well as replica KKK turbine housings. They do most of the Porsche KKK turbo rebuilds for Majestic in Waco I have been told.
Lastly, if anyone needs some serious exotic alloy/aluminum welding done, there is an absolute master of welding at a small place called Lonestar Metalworks near Long Point. Broken studs, cracked blocks, cracked heads - you name it he has fixed it for me. Usually charges about $20-40 per repair.
Old Jul 29, 2007 | 05:04 PM
robmd99's Avatar
Protomotive is in Ark. Closer than Imagine Auto
Old Jul 29, 2007 | 05:23 PM
eclou's Avatar
For some reason I thought Todd was in Florida. Good to know!
Old Jul 29, 2007 | 05:52 PM
houstonT's Avatar
houstonT Is a GOD !houstonT Is a GOD !houstonT Is a GOD !houstonT Is a GOD !houstonT Is a GOD !houstonT Is a GOD !houstonT Is a GOD !houstonT Is a GOD !houstonT Is a GOD !houstonT Is a GOD !houstonT Is a GOD !
OK, first hand...Jarrett has tuned many 996's successfully... Partly sarcastic mostly serious, give him a call if you want. I'm just helping you guys out with options, that's all...
Peter
Originally Posted by Dr_jitsu
peter,
I have already made arrangments, as you know, to have Todd K. tune my car. Unless I hear first hand that Jarret has succesfully tuned many 996's I am not going to even start the conversation. Now if I had a Viper, he would definately be my first call.
Old Jul 31, 2007 | 01:47 PM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Luis at Autodynamica is a stand up guy knows his stuff and has great customer service. He takes care of a couple of the High HP Porsche's in Houston. If your looking for a flash and the basics he is the Houston area EVO distributor.
Old Jul 31, 2007 | 02:35 PM
digitekkz's Avatar
digitekkz is infamous around these parts
what about Dallas? If RUF the only place? They are a bit overprice!!!
Old Jul 31, 2007 | 06:10 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
(one 900 whp TT and several Supras and Vipers).
Who has the 900whp TT in Houston.....why don't you invite him to 6 Speed?
Old Aug 1, 2007 | 08:50 AM
houstonT's Avatar
A 900 rwhp TT Porsche in Houston???? Am I reading that right?
Peter
Old Aug 1, 2007 | 08:59 AM
Bill W's Avatar
Bill W is infamous around these parts
Bob Norwood of Norwood Autocraft is in TX. He built the Doom Porsches, the doom cars used turbocharged 968 engines and pushed close to 1k hp.
Old Aug 1, 2007 | 09:00 AM
bmoores's Avatar
Are you talking about Bill Walls Turbo?? (900whp)........... Dr. Joe has seen bits and pieces of another gentlemans Porsche collection that has some quick P-Cars.
Old Aug 1, 2007 | 09:04 AM
eclou's Avatar
I saw a Norwood DOOM Ferrari TR make it perhaps 2/3 of a single lap around TWS before it blew. Talk about disappointment
Old Aug 1, 2007 | 12:59 PM
digitekkz's Avatar
Norwood does not do Porsche
Old Aug 1, 2007 | 01:40 PM
Dr_jitsu's Avatar
Rob MD's TT (built by Akram tuned by Protomotive) should be putting close to 900 at the wheels.
Old Aug 1, 2007 | 06:57 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
I thought Rob completed his build a LONG time ago. In fact, Rob posted the following 2.5 months ago (May 18):
I am slowing getting into the league.. Just fired up my Protomotive 3.8 liter kit!!! She sounds like a EVOMS eater ...... thanks EVOMS for not wanting to build my GT800....save money and was finished in two weeks vs 12 months..
https://www.6speedonline.com/forums/showpost.php?p=1111629&postcount=54
Back in May, Rob wrote that his car was "finishing in two weeks vs. 12 months" (and he went on to describe the sound as "a EVOMS eater"). Yet, Dr. J's post suggests that Rob's car was not "finished in two weeks" and is not done 2.5 months later (otherwise he would know the HP output). I admittedly am confused.
What is the status of Rob's car? What has been happening since Rob's May 18 post proclaiming the two week completion time (and thanking EVOMS for declining to accept the job)?
Thanks,
Craig
