Does Any One Know This Car?
Old Jul 29, 2007 | 06:15 AM
tomask50's Avatar
tomask50 is infamous around these parts
I bought my '03 X50 in March. The CarFax report said it was from IL. I'm trying to figure out if it was modded in any way.
It's black on black with these Techart door sills and red consol. It had 16K miles on it when I bought it.
Old Jul 29, 2007 | 06:34 AM
WOODTSTER's Avatar
How do we identify this car?
pics? serial number? anything unique about it?
MK
Old Jul 29, 2007 | 08:01 AM
justinmm2's Avatar
justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !
If you've ever seen more than 0.8 bar of boost, you're modded in at least one way...
Old Jul 29, 2007 | 02:27 PM
tomask50's Avatar
I need some internal work done and have been told it's covered under warranty if it has NOT been modded..e.g. flywheel, internal mods or maybe reflashed back to stock by Porsche; so I'm trying to find out before the dealer gets into it.
The car is black / black WITH A RED CENTER CONSOLE. VIN # WP0AB299X3S685144. From the Chicago area.
I'm having trouble pasting a picture.
Old Jul 29, 2007 | 02:43 PM
I recall LSM always has black P cars but I think he sold his earlier... which dealer did u buy it from?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 29, 2007 | 02:52 PM
tomask50's Avatar
Bought it in Dallas. They picked it up at a car aution.
Old Jul 29, 2007 | 05:15 PM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
its an x50, .8 should be stock...I would say more if you hit 1.0 its flashed. Its easy to tell. If you think you are, you can uninstall the ecu which takes all of 5 min (do a search) and it MAY have a sticker to tell you by whom. Then you can explain your situation and they can flash back to stock for relatively cheap and maybe when the work is done flash back for cheap.
Good luck, what internal work do you need done?
Old Jul 29, 2007 | 06:53 PM
tomask50's Avatar
Sounds like a rattle in the transmission. I've been told that a light weight flywheel will make the same noise. Soooo I'm trying to figure that out before goes in to fix it. If it's an aftermarket fly wheel, I waste a bunch of service time for them to tell me.
Old Jul 29, 2007 | 07:20 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
If the noise stays the same over the next few thousand miles I would leave it alone.Check to make sure the car is unflashed by running it in 4th gear from about 2500 rpms to 6000rpms and watch the boost gauge ....if it reads more than .8 bar your car has been flashed.Were the DV's ever changed .....take a look .....this is one of the first few mods one would do and not remove.If its been flashed and has different DV's then all likelyhood is someone swapped the dual mass flywheel to LWF and the noise would be normal.
Old Jul 30, 2007 | 09:47 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
My LWFW rattle (flywheel) goes away if I push the clutch pedal down...it is only heard at idle, not while moving except for the very start of first gear...fwiw.
Good luck.
Old Jul 30, 2007 | 10:11 AM
tomask50's Avatar
Thanks to all that answered... I'm pretty comfortable that Porsche owes me some work... I'm thinking sync'ros at this point.
I did notice that the clutch pedal has some ware on the outside lip.
Old Aug 7, 2007 | 08:47 PM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
That was my friend alex's car>>>also had mats with red "turbo S" lettering>
Lou
Old Aug 7, 2007 | 08:49 PM
LSM's Avatar
LSM
Senior Member
Yea but my 996TTnever had anything red inside!!
Old Aug 8, 2007 | 08:02 AM
tomask50's Avatar
Lou
Can you have your friend Alex contact me about the car? tom@kerbydevelopment.com
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
gulf gt
Aug 27, 2015 10:27 AM
Wheel Experts
American Muscle
Aug 19, 2015 09:07 AM
