Quick question !
Old Aug 2, 2007 | 10:30 AM
Joe Weinstein's Avatar
Markski, you can do an easy experiment:
drive your car in 3rd at about 45 mph. Set your cruise
control to keep it there, on a level road. Observe the
RPMs. Then shift to 4th and observe the RPMs, as the
car stays at 45mph. The drop in RPM should be just about
half what the drop would be at 6500 rpm. I base that on
the chart which lists the speed as 90-92 mph at 6500 rpm
in 3rd. You can verify, because at 45 mph in third, the
RPMs should be 3250. If it's not, adjust your speed so it
is 3250. Then the drop when you shift up *will be* half
what it would be if you shifted at twice the RPM.
Joe
Old Aug 2, 2007 | 10:32 AM
Al is right too of course. My numbers assume no appreciable drop in speed.
Old Aug 2, 2007 | 10:39 AM
If someone does not want to go up to 6500 RPMs take it to 4K RPMs and tell me what it drops to when u get into 4th...
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 2, 2007 | 10:59 AM
Shifting at 4k will be a drop of 4000/6500 * 1375 RPM = 915 RPM drop
Old Aug 2, 2007 | 12:28 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Shifting at 4000 in 3rd gear it goes down to 3100 in 4th. I just came back from lunch. Its raining here in Houston, as usual, so I could not make any big 3rd/4th pulls.
Old Aug 2, 2007 | 12:40 PM
thanks Powell, that confirms my numbers.
Joe
Old Aug 5, 2007 | 01:40 PM
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
Mark
Here is your RPM drop chart, this is from your run. Bear in mind this is extracted from your speed so it does not look very neat.
All seems ok. Obviously the scale on the left is RPMs not FWHP...
Old Aug 5, 2007 | 01:55 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Originally Posted by Powell
I should have paid attention on the way to work this morning. Made a 3rd to 4th pull on the freeway, but only was watching the boost (which was only disappointing LOL).
On the way home tonight I'll make a pass, but you'll probably have an answer by then.
Nice meeting you last night at RSI. Hope to see you at the Texas Jam. Hey Marek, thanks for the presents!
Robert
PorscheEnthusiast
Nov 13, 2015 02:23 PM
GetALife75
New Member Introductions
Sep 3, 2015 12:22 PM
The Oss
Aug 24, 2015 08:19 PM
