Spoiler stuck down
Old Aug 2, 2007 | 09:04 PM
stefenolsen's Avatar
stefenolsen is infamous around these parts
Unhappy Spoiler stuck down
My rear spoiler on my 2001tt is stuck in the down position. Does anyone know if there is a way to raise it manually? I just ordered a Misha GT2 wing blade and I need to raise the spoiler to get the new wing on, after that I plan on disconnecting it all together. Thanks to everyone in advance.
Old Aug 2, 2007 | 09:27 PM
Zuma 911's Avatar
Zuma 911 has a spectacular aura aboutZuma 911 has a spectacular aura about
Things to check
You have probably already cycled the dash switch, and checked the fuse. Sometimes get up to 75+ jars it loose if it's stuck, after that you probably will have to replace the actuator, maybe someone else can add to troubleshooting tips. Once you get it up, heres a few photos that may help. I found using the tool made it very easy (less than 5 minutes). I got mine through samstag for $15 bucks...I recommend it. Good Luck.
http://www.samstagsales.com/Porsche.htm
http://s182.photobucket.com/albums/x...rent=wing1.jpg
http://s182.photobucket.com/albums/x...rent=wing3.jpg
http://s182.photobucket.com/albums/x...rent=wing2.jpg
markj
Oct 7, 2015 01:24 PM
viprklr
Sep 27, 2015 11:44 AM
