Broke Crank At The Track!!!
Old Aug 12, 2007 | 02:19 PM
  #121
tom kerr's Avatar
Originally Posted by drjoe
Tom, you really need to lose some weight then...3100lbs is doable...
I know, I have not done anything ridiculous yet!!
Old Aug 12, 2007 | 07:43 PM
  #122
sechsgang's Avatar
sechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant future
Originally Posted by tom kerr
A too late, new engine on its way. Any thoughts on how to protect this thing at the track? I am trying to get an oil temp guage, accurate boost gauge, A/F gauge and some more driving lessions!!
I am going to run the X-50 stock but sadly I dont think it will be enough for the new Z06's and GT3's at that power level.
I had enough trouble with 500+ hp, 3300pound, racing suspension and hoosiers for gosh sake!!
Would like your thought about your car and mods at the track now that my crank broke!!
the new z06s are a handful but the gt3s acutally arent awefully hard to catch...you just have to use your huge torque advantage and slow in fast out to slow up the NA guys and then power away while they are still clamoring in 1st gear or low 2nd...
As for CAR mods, I would say hands down a bi-adj race suspension is in order and 200 more lbs out wouldnt hurt...haha...as for engine, im running stock motor with just exhaust and still wailing on most of the standard DE competition...well see about the gt3s at my next clubrace...
Old Aug 12, 2007 | 09:39 PM
  #123
tom kerr's Avatar
Keep up the good work! Your car weighs 3100 pounds?
Are we talking about the 997 GT3? I have no problem with the 996's but man the 997's are fast!!!
Old Aug 13, 2007 | 05:59 AM
  #124
sechsgang's Avatar
oh, nah, my car is still prolly inbetween 3200 and 3300...otherwise I move up a class and get my *** handed to be my gt2s...
And the 997s are really quick, but I dont acutally know if they are in my class or not as the 415hp puts them near the 420 i have stock but with a couple hundred llbs less weight...that said, if you have around 480 hp with a turbo and a great setup...well, anything is possible with the "right" driving around a track...haha...you know that though
Old Aug 13, 2007 | 09:28 AM
  #125
Brett B's Avatar
Brett B is infamous around these parts
Originally Posted by roadsterdoc
This statement clearly shows that you are the one more interested in being right than learning anything. You consider a plane engine not being relevant? That is ...really! C'mon now, engine failure in a plane is kind of a bad thing don't ya think? I don't mean to be a jerk... Step back and look at the big picture. WBs and EGTs each have their place. They are both useful for tuning, monitoring and diagnosing.
Please read what was written a bit more carefully. I never stated that EGTs were useless. Nor did I state that aircraft engine failures were insignificant. However, compared to the dynamics of a car at a race track, most aircraft engines operate under a nearly steady state loading condition. EGT’s work fine in this application as the hysteresis associated with probe heat up time is minimized and ignition timing is relatively static. Fatigue failures of the probes themselves are also minimized in aircraft as the total heat/cool cycles are a fraction of those seen in a car used for road racing.
Many aircraft engines are still carbureted as well, that doesn’t mean a carburetor is the best choice for the topic at hand. Therefore, the argument of “it’s used in aircraft†is irrelevant to the situations we are discussing here. Making statements of that sort indicates somebody who is reaching, but maybe that’s just my interpretation.
And I agree, using both is great. But if choosing either/or, using an EGT instead of a wideband is a poor choice since it is a secondary measurement to ideal combustion and is dependent on so many other factors.
Old Aug 13, 2007 | 09:36 AM
  #126
Brett B's Avatar
Originally Posted by eclou
EGT thermocouplers are not exactly fragile. For engine monitoring most are placed within 4 inches of the piston on the primary runners. You can never get a O2 sensor that close which is why you can't monitor each cylinder with an O2 sensor. Plus O2 sensors ARE quite fragile and prone to fouling especially when it comes to fuel additives. Ever notice most dynos have a pile of working/non working wideband sensors? You can at best monitor 1 bank at a time which may or may not help to prevent a disaster but it is unlikely. I am not by any means saying the AFR is useless - I run a Zeitronix in my track car with EGT and wideband - but watching an AFR is like watching a VU meter.
EGT's can be mounted pre-turbo to help diagnose combustion problems and post turbo to help prevent turbo heat failures. Widebands cannot tell you if your turbo is cooking. There is no reason not to have both, as the combined info can fully help solve problems more readily.
The EGT temps in aircraft and in automobile engines follow the same ranges and same rules. What is useful in the aircraft is no less useful in a car, especially since aircraft pilots rely on the engine for their lives. Doesn't that speak for itself regard the usefulness of the EGT?
EGT’s are indeed useful if you are worried about turbo life. But again, that is not what we are talking about here is it? This is a thread about an engine failure, not a turbo failure. So these statements are again irrelevant to what would be most useful to help Tom prevent future engine failures.
Maybe you should try a better wideband, the Zeitronix isn’t exactly what I would choose for easy viewing. A bunch of numbers flashing on a screen aren’t useful in about any driving situation. Once again, I have absolutely no problem recognizing a lean condition thanks to the colored warning LED’s of the AEM in my car (or any of the cars I have tuned). You really should consider trying one out as it's a pretty good product:
http://www.aempower.com/ViewCategory.aspx?CategoryID=67
I take it your 944 is your track car? Where do you have your wideband display mounted? I watched the video of it, and I don’t see a wideband in plan sight anywhere unless it’s mounted out of camera view on the A-pillar. Regardless, if you genuinely think that an EGT will properly alert you in time to prevent engine failure due to a lean condition (on one or multiple cylinders), and a wideband will not, then I really don't have anything else to say.
Old Aug 13, 2007 | 01:26 PM
  #127
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
Brett,
this is precisely why an EGT can be more useful than a wideband in monitoring an engine's health during stress loads. I am sure that you are aware many cars have failures running perfectly tuned AFR's. The modern OBD II Motronics monitor 4 O2 sensors (though not wideband) several times per second. The thing that kills engines, especially FI engines is heat. The EGT measures combustion chamber heat and gives clues to whether or not multiple factors are at optimal or not. The AFR measures just AFR. It will not tell you if you are knocking/pinging/pre-detonating, if you have a fuel quality problem, if you are at risk of burning a piston or a valve, or if you are about to cook a turbo. It is slower reacting by far than a wideband, but the wideband lean-out disaster is still only one possible mode of failure.
For me, I have been using the EGT in a very crude application. I run a single EGT on my crossover pipe. I have bungs on all 4 of my primaries but run a very conservative boost and fuel map for track. I am looking primarily at preventing turbo failure and burning valves/pistons and not at all at optimal power. The Zeitronix I have mounted in the console down by the radio where it is far out of the line of sight, but I am only sweeping the guages - EGT, AFR, oil temp, water temp, boost once per lap on the long straight of TWS when the engine is under max load. If it blows, I am out only about $1k. For a tt the cost of failure is much, much higher.
Old Aug 13, 2007 | 02:48 PM
  #128
Brett B's Avatar
This is not correct, as a lean condition is not the only thing you are looking for. When my ECU detects detonation from any cause (be it too lean, heat soaked, too aggressive timing, poor fuel, etc), it retards timing and adds fuel. My A/F ratio at WOT in full boost is a flat 11.6:1 across the board (with no running issues). If my ECU thinks it sees detonation via the knock sensors, it adds fuel and my A/F curve instantly dips into the 10’s. The wideband registers this addition of fuel, hence giving me a visual indication of detonation for ANY reason within 200-300 milliseconds.
At this point I do not care why it detonating, all I care to know is that it DID see some detonation, and I need to back off the throttle or suffer engine damage. The wideband tells me this every single time without failure regardless of cause. It is a very simple method that takes advantage of the ECU’s built in knock feedback controls.
The EGT will not show an increase in temp (due to the now retarded timing) for several seconds of WOT, and possibly not at all if the pull is not long enough to properly heat up the probe, leaving you completely unaware that your engine is experiencing detonation for an extended period of time. This is not a good situation to be in. Most engines can only survive through some small amounts detonation before suffering severe damage. The time it takes for an EGT to show ANY indication of a non-ideal running condition compared to the ~300 millisecond response of a wideband often makes the difference between a close call and catastrophic failure.
Old Aug 13, 2007 | 04:07 PM
  #129
eclou's Avatar
Brett,
your AFR going rich is probably due to profound timing retardation rather than the ECU adding fuel. As far as I know I don't think the computer is ever going to add fuel to a cylinder that is already detonating. Detonation will cause lower EGT's and higher cylinder head temps, not higher EGTs.
I think you have made it clear that we are going to have to agree to disagree.
Old Aug 13, 2007 | 06:44 PM
  #130
eclou's Avatar
Originally Posted by Kevin
For what it's worth..
Once the ECU picks up detonation, the ECU retards timing and floods/dumps fuel....
Interesting. I would have thought retardation/cutting spark might be enough. I guess if it is pre-igniting though, the flame path already exists.
Old Aug 13, 2007 | 07:41 PM
  #131
Brett B's Avatar
Brett,
When the ECU sees detonation, it pulls timing. When timing is retarded, EGT’s do indeed increase. This is a very well-known fact of ignition tuning.
The A/F ratio will not change even if the ECU pulls 20 degrees of timing (assuming no misfiring).
The A/F will only change when the ECU adds fuel, which it does in combination with pulling timing when it detects detonation, as Kevin verified.
This is true for the stock 996 ECU, as well as other OEM and aftermarket ECUs such as the one I am currently running. Below is a screen shot showing how the ECU I am using reacts when knock is detected. My A/F goes rich upon the ECU seeing knock because that is what I have programmed it to do. Dumping fuel is one of the most effective ways to combat detonation, as pulling timing (even a large amount) is only helpful to a point.
Old Aug 13, 2007 | 08:02 PM
  #132
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
how many people who regularly track their cars have all these "extra" gauges?
and are they necessary just because we have changed our ECU's??
Tom, I track my car about 5-6 events a year , I installed an oil temp, fuel pressure & boost. I set them @ the peak levels I want (audio alarms). Just in case! I might be able to save the engine ...tom
Old Aug 14, 2007 | 08:22 AM
  #133
tom kerr's Avatar
thanks, going to do the same!!
what's better the A/F gauge or fuel pressure, I was going with the A/F
Old Aug 15, 2007 | 09:19 PM
  #134
2quickturbo's Avatar
2quickturbo is infamous around these parts
Tom, sorry to see your car down , at least you know it's in good hands. By the way i have your twin in Tampa in the same shop! Sucks to see your car that way, hopefully your experience helps others as it did me.
Old Aug 16, 2007 | 08:02 AM
  #135
tom kerr's Avatar
Danny,
saw your car, very nice!! sorry about the tranny sounds like at least it is covered!!
my engine came in today go check it out, I'll posts pics later
tom
