waste gate question
Old Aug 18, 2007 | 10:40 PM
wross996TT's Avatar
You should adjust the wastegates in the car with your program...doesn't matter whos it is just adjust for your car...
Old Aug 19, 2007 | 10:31 AM
fastoc996twint's Avatar
fastoc996twint is infamous around these parts
can i adjust my stock waste gates on my stock x50 car? if so any gains?
Old Aug 19, 2007 | 11:06 AM
wross996TT's Avatar
What boost are you holding now? That would be in 4th or 5th WOT...The problem is the stock springs may not be enough...although you can certainly try adjusting...this can be dangerous (you need to adjust both identically).
Old Aug 19, 2007 | 01:40 PM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
Arrow
I did adjust eh OEM WG as best and safe as I could and I could hold just 1.2 until 4,400 rpms..thus, the adjusted OEM just give a good spike but does not compare with the EVO WG.
wross996TT is right ...be careful if needed adjusting and see your bost level at 4th and 5th gear
Old Aug 19, 2007 | 04:59 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
am at 1,2 spikes to1.3 only use 100 oct... think i'll leave em alone
Old Aug 20, 2007 | 12:20 AM
what waste gates are you running,, how much? do they come with directions on how to adjust?
Old Aug 20, 2007 | 12:26 AM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
I got them from Shark Werks for about $385 plus shipping. Installation is pretty straight forward and there are many links regarding adjusting on 6speed.
Old Aug 20, 2007 | 12:50 AM
so i am better of with these... they are better thast just replacing the d/v's?
Old Aug 20, 2007 | 08:01 AM
wross996TT's Avatar
You need to answer my questions above....it is not all about boost. There is a maximum you will get before you have maxed out the turbos. The DVs are a different item (do not mix the discussion). It is suggested you upgrade these for prevention (failure of the plastc stock DVs)...not performance.
Old Aug 20, 2007 | 12:15 PM
im hlding abought 0.9 to 1.0 max pressure.
Old Aug 20, 2007 | 01:41 PM
wross996TT's Avatar
With flash you should be seeing 1.2 (spikes of 1.3) in 4th & 5th WOT...so if you have flashed, your wastegates could use some adjustment or upgrading the springs.
dylanX
Cayenne
11
Nov 23, 2015 10:31 AM
03EvoIII
Sep 21, 2015 04:38 PM
GetALife75
New Member Introductions
Sep 3, 2015 12:22 PM
