check engine light
Old Aug 24, 2007 | 10:14 PM
igdawgi's Avatar
igdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud of
check engine light
does the check engine light comes on to remind of maintenance? I have 25590 miles and the light popped on.. bringing to dealer monday.... aghh.. hopefully nothing major....
Old Aug 25, 2007 | 08:11 AM
wross996TT's Avatar
NTMK...you threw a code
Old Aug 26, 2007 | 12:31 AM
Beej's Avatar
Beej is infamous around these parts
Yep - this means the computer/OBDII diagnostics have detected a problem and thrown an error code - you need the dealer to read it and find out what the problem is.
PS: My 2001 TT threw a code 3 weeks ago, I took it to my dealer, the code was caused by a bad boost leak that had developed; car currently still at dealer with the engine out being fixed Thanks goodness it is a CPO'd car with warranty!
Beej
Old Aug 26, 2007 | 12:50 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Beej
I would be interested to know what your problem was, 3 weeks at dealer for boost leak, must be serious! If you could let us now exact problem that would be great!
Old Aug 26, 2007 | 11:49 AM
igdawgi's Avatar
I'll keep everyone posted... bringing to a shop in dublin called kahler's.. hopefully they can fix the issue..
Old Aug 27, 2007 | 07:16 AM
Beej's Avatar
Sure. It's taking so long because a) it's a warranty job and wasn't scheduled and the workshop is kinda busy (there's not many dealers over here in Oz and too many Boxters and Cayennes!! ), and b) hardly any parts ever in stock for 911 turbo's so everything has to be ordered in from Germany.
The first problem they found was some gasket in the induction that was leaking - however they fixed that ( 1+ week later when the part arrived!) and boost was still leaking, and they couldn't find where. So that was when they decided to pull the engine out, which has now been done. Everything has been pressure tested and they are now saying that most of the induction plastic piping has to be replaced as there are small cracks that are leaking boost under high pressure (can be seen clearly with the smoke test), plus the DVs are also not sealing fully (although that is only minor at this stage). Fortuneately, it's mostly being fixed now under warranty (except for the DVs which they are arguing are not covered!), and I should be back on the road in a week or so.
Has anyone ever had this problem with the induction pipes/hoses and gaskets going off and leaking?
My car is a 2001 6 speed, has only 37.5k miles, and other than this issue otherwise is in pristine condition mechanically and in every other way, has complete maintenance records, and was a one owner, Porsche certified car when I bought it. I am struggling to understand why those sorts of parts should just fail in a car with low mileage and only 6 years old? It is a little concerning......
Cheers,
Beej
Old Aug 27, 2007 | 06:45 PM
igdawgi's Avatar
I havent taken the car into the dearlership yet. I realized I have a warranty on my car but just needs to be transfered over to my name.. So waiting for this to happen. I will report once I get news asap
Old Aug 30, 2007 | 02:18 PM
igdawgi's Avatar
secondary airbox bank 1 and bank 2 error??? car is sitting at khaler's right now getting service and to track the issue..
Old Aug 30, 2007 | 05:22 PM
wross996TT's Avatar
It reaslly helps when you can provide the actual fault code #
for example:
P0491
Secondary Air Injection System, Bank 1 – Below Limit
Possible fault cause
♦ Secondary air injection pump is not triggered
♦ Secondary air injection pump does not work
♦ Air supply lines restricted
♦ Electric change-over valve does not function
♦ Air change-over valve does not function
♦ Vacuum system leaking
P0410, 80 Secondary Air Injection System, Bank 1 – Below
Limit:
P1411
208 Secondary Air Injection System, Bank 2 – Below
Limit
♦ Vacuum system leaks
MY best guess is a leak!
Old Aug 31, 2007 | 12:44 AM
igdawgi's Avatar
They just worked on getting to the 30k maintenance. They will have more information on the check engine light tomorrow. Since they have everything apart... Anything I should change??? Intake??? Pipes??? etc...
Old Aug 31, 2007 | 02:00 AM
4G64T's Avatar
4G64T is infamous around these parts
You should look at changing the DV and replacing the Boost hoses with Silicone ones for a start.
Old Aug 31, 2007 | 08:43 PM
igdawgi's Avatar
Got the car back... Turbo Cut off valves were leaking... Nothing major or big... whew...
Old Sep 1, 2007 | 09:05 AM
wross996TT's Avatar
I love being right...LOL glad you got it figured out
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
The Oss
Aug 24, 2015 08:19 PM
