High RPM's and Delay when shifting
When shifting from 1st to second in my '01 911TT, I notice that when I am accelerating hard, the RPM's rise but the car does not pick up speed until a second or two later. This is also experienced in latter gears. Is this a case of Extreme Turbo Lag or...???
Thanks.
Thanks.
1st gear is too low in these cars IMHO. Probably is it. I agree....no real go in 1st.
Flywheel does matter....
If clutch...go to fourth, floor it...do you revs shoot up without touching the clutch pedal?...
Good luck!
Good luck!
See my sig for what I did when the same thing happened to me.
I went with a complete package. My "feel" is at least as good as new OEM stock...and I have a LOT more power....
Good luck.
Good luck.
Also, it may be that you are getting wheel spin in 2nd gear, so PSM may be kicking in. Try turning the PSM off and do the same kind of hard acceleration. It may be the clutch too, and I think your accumulator is bad too. I have the same issue.
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
Oct 6, 2015 03:43 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
