Anyone using the HR coil over kit?
Old May 4, 2004 | 10:19 PM
02TurboX50's Avatar
02TurboX50 is infamous around these parts
I hear about the PSS9 kit all the time on this board, but I don't hear too much about the H&R coil over kit. Since H&R does manufacturing and R&D in Germany, I would think the kit should be high quality and high performance. I know the cost on the kit is the same as the PSS9 too.
While at the Car and Driver Supercar Challenge a couple years back I know the 750hp Autothority car had this system and it ran away with the road course portion of the competition. They spared no expense on that car so it definitely has me wondering why they used this system over the other ones out there....
Looking for someone with first hand experience with this system.
Thanks!
Old May 4, 2004 | 11:31 PM
Code Red's Avatar
Code Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to behold
Don't get it the car will scrap everything even at the highest setting. Very marginal customer service as well.
Old May 5, 2004 | 12:01 AM
msindi's Avatar
Bilstein who makes the PSS-9 is also in Germany...Techart, RUF and FVD to name a few reputable tuners all use PSS-9 based coilovers...
Old May 5, 2004 | 12:45 AM
NelsonF's Avatar
NelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to behold
I swithed from stock to the ROW set-up after doing a couple of DE's. Then I went to H&R coilovers with GT3 bars and TRG adjustable drop links to go with my wider Fikse 18/Corsa setup.
I have to say that I'm very pleased with the performance. The car is lower approx 30mm front and 25mm back(front spoiler can rub significant incline/delclines if I'm not careful so I switched to C4S front spoiler-now 3.5"front clearance) and feels great and very balanced. The only thing that occasionally rubs now(only on fast roads with major undulations) is my GT3 brake air ducts which are significantly lower than stock but worth it. I've adjusted for much less understeer and have a semi-agressive alignment with medium agressive camber. The car feels much more neutral
and tossable w/ very good stability on fast sweepers. It now has a slightly edgy but controllable feel at high speeds vs the previous push. I'm hearing of better set-ups out there (Motons) but for the occasional track and DE's, my H&R set up is fine.
Old May 5, 2004 | 01:48 AM
gneypiks's Avatar
gneypiks is infamous around these partsgneypiks is infamous around these parts
have had mine for abt 6 mnths now,its the newer version( with the helper springs)supposed to eradicate those annoying noises,but no,it doesnt.other than the noise issues,ride height n handling is perfect for my usage.
Old May 5, 2004 | 04:22 PM
20C4S's Avatar
second that!
Highlander
Jan 3, 2020 03:14 PM
orbelo
Aug 30, 2015 12:26 PM
Fuzzo
Cayenne 955/957
Aug 26, 2015 09:45 AM
oddjob142
Aug 24, 2015 05:49 PM
Highlander
Aug 23, 2015 09:05 PM
