Doing a Proper Corner Balance Alignment
Old Sep 13, 2007 | 06:19 PM
vividracing's Avatar
I just thought I would share this info and pictures of a proper corner balance alignment done on a Porsche 996TT. Redline Motorsports in AZ is probably the most knowledgeable Porsche suspension shop in the Southwest. He does a ton of Porsche cup cars with Motons and is now hooked on JIC's too. Well after I put my 19's on it, it needed some adjustment. I like to set the car to GT2 specs and he handles the rest Check out the spec sheets and give him a call for any tech questions on alignments.
More pics here -
http://www.myvividracing.com/gallery...ages.php?c=273
Old Sep 13, 2007 | 06:29 PM
unvmy996's Avatar
how much of a diff , does corner balance alignment make over a really good alignment ?? cuase im having the JIC installed monday , by TPC racing , and they are aligning the car also ...should i ask for corner balancing ?
Old Sep 13, 2007 | 11:58 PM
fly2low's Avatar
fly2low is infamous around these parts
corner balance = yes
Old Sep 14, 2007 | 05:49 AM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
thats a cool shot up on the scales!
Old Sep 14, 2007 | 06:47 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Very few shops have that nice a set up.
Old Sep 14, 2007 | 07:02 AM
Phoenix's Avatar
Phoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant future
Indeed.
Thanks for the pics, Dan.
Old Sep 14, 2007 | 09:28 AM
Makes a huge difference. Have them set the car up to GT2 specs. If you have not gotten a sway bar, do the rear H&R only, AP control arms, and AP sway bar links in the rear, best handling street/weekend racer ever.
I am sure Redline appreciates the comments
Old Sep 14, 2007 | 10:22 AM
unvmy996's Avatar
Dan ,i have TPC racing full adjustable sways , front and rear , TPC link in the rear , and adustable rear toe. JIC's going on monday .
Old Sep 14, 2007 | 10:31 AM
then you will be dialed!
Old Sep 14, 2007 | 10:43 AM
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
I am not sure I am reading this thread correctly but I don't see any corner balance numbers, do you not mean corner weight balance?
I take it this is not for a street/track/DE car. Also, a couple of the values are a bit out of spec but pretty well balanced overall.
Old Sep 14, 2007 | 10:49 AM
The car has been balanced at all 4 corners and aligned accordingly.
Old Sep 14, 2007 | 10:52 AM
Jean's Avatar
Can you show the corner weights? That is really the interesting reading I thought?
Old Sep 14, 2007 | 10:57 AM
CSD952's Avatar
CSD952 is infamous around these parts
I would be interested in seeing the corner balance numbers before and after as well as the alignment numbers shown here. For me it is the main reason to upgrade to a spring perch adjustable suspension and sway bar set up. It would be interesting to see what movement can be made.
Old Sep 14, 2007 | 11:08 AM
Jean's Avatar
Doing the alignment without corner balancing is a total waste of money if you are changing shocks!! If you do it, make sure you get a printout of the weight side to side, front to rear, and diagonally. I would think that Levitas would not accept to let you go after changing your shocks without having done it before.
Old Sep 14, 2007 | 12:41 PM
Joe Weinstein's Avatar
Yep. The meaning of corner-balancing is getting the corner weights
right. The data in this thread is about alignment, which is important,
but that it what you do after you've done a corner-balance.
I too would like to see the before and after corner weights.
I can run them through a program that calculates the ideals...
Joe
