Suspension advice?
Old May 9, 2004 | 10:30 PM
Red Devil's Avatar
Red Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to all
Suspension advice?
My car has the older H&R coilovers installed about Jan-Feb 2002. My mechanic just raised the car a bit but said that was it due to design of the suspension. It got me to thinking of how much better from a street-driving perspective some of the newer suspensions out there are. I don't think my car will ever see the track, so a bit softer ride and a little more height than I have would be what I'm after. My current height from level ground to the mid-point of the well arch is 25 3/8 front and 25 1/8 rear. I'm running 19's with 315/25 rear and 235/35 front. My mechanic suggested I could go to a tire with a higher profile to raise the height and also soften it a bit. I'm just concerned over doing that and then rubbing b/c i can't raise the car any more. Any opinions on the suspension and any advice on what tire size might work in his idea? TIA
Old May 9, 2004 | 10:37 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Drjim, If you would like to see the X73 setup that I have in the Turbo here and get a feel for it, you are more than welcome to.
Old May 10, 2004 | 08:18 AM
Red Devil's Avatar
I'm a little rusty, but what is the X73? Is it the ROW set-up?
Old May 10, 2004 | 08:53 AM
Turbo Ron's Avatar
Turbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to all
Its alot stiffer and lower. You might want to go with the pss9 for the streets. Contact Lucent Motors. Great prices, great mechanics.
Old May 10, 2004 | 08:54 AM
JASCLASS's Avatar
The X73 is an optional Porsche suspension in Europe, its more aggressive and lower than the ROW, it is available throught Gert at CARNEWAL and its a great balance for street and track use.
Old May 10, 2004 | 06:56 PM
Red Devil's Avatar
Justin, maybe we'll hook up over the next few weeks. I think Rave has put a different suspension on his car, so maybe a (swap) meet.
Old May 10, 2004 | 09:33 PM
drbill's Avatar
drbill is infamous around these parts
i remember the day you purchased this car a little over a year ago and someone saying-" i paid --- grand for the car and it has every mod already and won't have to put any more $$$ into it so it's a great deal... sounds like the Jim i know is getting caught in a catch! guess the shadow of the ghostly Dr Bill's foolish spending is still hovering over the forum...
Old May 11, 2004 | 01:01 AM
james's Avatar
Carolina Speed
james is infamous around these parts
Do I understand the current setup correctly? Is the front of the car 1/4" higher in the front? The rake needs to be lower in the front. I would recommend PSS-9's even if you don't track b/c you can set the car height higher or lower while it is fairly easy to change the settings on the piston at home.
Old May 11, 2004 | 07:28 PM
Red Devil's Avatar
I believe the car is dead level, even though the height measurement levels indicate otherwise. The mechanic told me this was what the correct set-up should be. Even if a little front rake IS desireable, in my case it would worsten the lip clearance. If I can gain some clearance without rubbing by increasing the sidewall height, it won't be much. I don't understand why the H&R is so limiting, but maybe that's why they were improved. If I do change, it would be to one that gave me the freedom to go from stock to where I am now and in between.
As for Hummer Bill, you know I only change after I've thought it through for a while. I've owned the car for a year and a half, which may be half of the time it will spend here. I think spending a few bucks to make it more useable might be worth it in the long run.
Old May 11, 2004 | 07:55 PM
james's Avatar
Carolina Speed
red devil, you sound way too sensible for this group of modaholics. Either that or the modders just talk the most. The only reason I asked about rake is b/c when you gas it, the car has a subtle tendency to squat, and a dead level 911 will nose up a tad with brisk acceleration. This might lead to stability issues. I don't think there is any worry you're going to go "GT-1 at Road Atlanta (fly up and flip over)" or anything, but you might notice a wiggle or a noise. If you haven't had any problems then that is great. Just trying to help with the persuit of perfection.
Old May 11, 2004 | 10:22 PM
DrJim's Avatar
DrJim is infamous around these parts
Actually, websites are the root of all evil when it comes to modifications. That is, I blame them for the modifications I have done, purchased or will do in the future. I admire from arm's length those early-adaptors who blaze their own (modifying) path.
Old May 11, 2004 | 11:34 PM
eride996's Avatar
eride996 is infamous around these parts
red devil,
you can not increase the height of the side wall unless you plan on rubbing you radiator. pss9 would be your only real option.
Old May 12, 2004 | 06:45 PM
Red Devil's Avatar
Originally posted by eride996
red devil,
Please explain. I haven't looked inside the well but would really shudder to think that this was the item most likely to rub. (PS, I'm not lazy, the car isn't here for me to look)
Old May 12, 2004 | 10:07 PM
MKW's Avatar
MKW
MKW is infamous around these parts
You can't compare front/rear wheel arch heights to assess chassis levelness . There is a 7mm difference in wheel arch to suspension arm reference point distance comparing front and rear suspensions. That's why factory specs for ride height are set at reference points on the suspension arms, not wheel arches , esp since body panel fit can affect that even more.
The way the car visually sits and the way the chassis is set up are two different things.
BenTT
Jul 22, 2021 02:38 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
Slikknikk
American Muscle
Sep 8, 2015 06:38 PM
