Fire Extinguisher mount - How/Where??
Old Sep 27, 2007 | 08:21 AM
slant911's Avatar
slant911 is infamous around these parts
I have my first event coming up this weekend and they require a fire extinguisher on board in a metal bracketed mount. I've got the extinguisher and it has a metal mount. Where do you guys put it? Further, this is by no means a "race car" and this extinguisher will not be staying. What is the best way to mount so afterwards you can't even tell it was there? Are there mounts that are safe yet not so permanant as drilling holes?
Any suggestions please.
Thanks.
John
Old Sep 27, 2007 | 08:31 AM
WOODTSTER's Avatar
I would like to know about options also.
I have a 4 pt roll bar with cross bracing.
MK
BTW: Sharkey had a real swanky looking mount.
Old Sep 27, 2007 | 10:34 AM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
If you have GT3 seats, you can use a BK fire extinguisher mount and it will mount like the picture below. If you have sport seats there are two tabs facing forward under the seat cushion that have holes in them. I fabricated two steel pieces to mount to the tabs and long enough to then mount to the extinguisher braket and that worked well, too. This method placed the extinguisher in the same spot as the BK brakets in the picture below. I am not sure if the regular seats have these tabs, though.
Old Sep 27, 2007 | 10:38 AM
Mikelly's Avatar
Yup, that's the one I have from BREY KRAUS, bought thru CDOC or one of the other suppliers... Get the Anti-sub belt mount and do them both while you're at it!
Mike
Old Sep 28, 2007 | 01:22 PM
slant911's Avatar
John,
Not sure if I have the "sport seats" or not, but I did look under the seats and there is a plate attached to the seat that is about 4-5 inches long but is tucked way too far under there to mount directly to it. So I have some diamond plate material (about 1/8") that I'm going to cut out and fab up as an "extension" if you will to that seat plate so as to push the mounting out from under the seat so much. Hard to explain unless you've crawled under there. Anyway, I'll try and take some pics along the way so if the info is needed by anyone later. I kinda suck at resizing them and what not though
Anyhow, thanks for the info I think this will work. Well it better as something needs to be mounted by 7:00 Sunday morning...
Old Sep 28, 2007 | 02:00 PM
John D's Avatar
That's what I did before I had the GT3 seats...you're on the right track.
Old Sep 28, 2007 | 05:01 PM
DeAd-EyE's Avatar
DeAd-EyE is infamous around these parts
+1
dude..sharkey's fire-extinguisher setup is awsome! so gangster.
adnanm3
Nov 22, 2023 02:43 AM
BLKMGK
May 31, 2016 04:32 AM
Axxlrod
Oct 26, 2015 11:54 AM
jaehoppa
Oct 22, 2015 09:17 PM
