DCTMS T96 Sport steering wheel for 996/986 models
#136
Nice, looks good
Ill be installing mine shortly, DCT send me a generic Youtube video on how to remove the OEM wheel.
Any other tips or tricks that you have or was it as simple as removing the 2 screws to remove the airbag and then the one nut holding the actual wheel? it looks fairly straight forward
#141
Swap the ground wires.
#142
Cant swap the grounds...the wires are perfect length so you can't make that mistake
But I figured it out. I fully tightened down the pressure plate under the airbag when I swapped it from the old wheel to the T96. Just backed it off a turn and all good.
This wheel is such a big improvement over stock!
#143
If you are tall, the smaller diameter wheel with a flat bottom is great combo!
#144
I really like the flat bottom, definitely a style upgrade
The feel of this wheel over stock is amazing.
Dropping the oil and installing the Numeric SSK tomorrow!
#145
The Numeric SSK is a great unit. In the future add the RSS motor mounts and 997 trans mount for the (IHMO) total unsurpassed shifter feel.
#146
the engine mount is on my list of upgrades, the trans mount looks a lot more complicated to do
Can you get away with just the motor mounts??
#147
My indy swapped out the trans mount in about 20 mins on a lift.
#149
Carbon option wheels
Can you add the Tip paddle shift to your carbon fiber version wheels? If you can, will you PM price on this option wrapped in Carbon and savanna beige combo with paddle shift? Or can you re-wrap my original wheel and add the paddle shift to it?
-C
-C
