difference between 996tt and 996
Old Nov 11, 2007 | 04:14 PM
nogelgee64's Avatar
nogelgee64 is infamous around these parts
what is the difference internally between the n/a motor and the turbo?
Old Nov 11, 2007 | 05:49 PM
jumper5836's Avatar
jumper5836 has a spectacular aura aboutjumper5836 has a spectacular aura about
they are totally different engines.
Old Nov 11, 2007 | 07:28 PM
nogelgee64's Avatar
thanks
Old Nov 12, 2007 | 11:01 AM
GREERJ1's Avatar
GREERJ1 is infamous around these parts
about 150 hp also
Old Nov 12, 2007 | 11:19 AM
otherhwhitemeat's Avatar
otherhwhitemeat is infamous around these parts
996tt- air cooled case/ water cooled heads
996- water cooled case and heads
way different
Old Nov 12, 2007 | 01:27 PM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
The TT uses a dry sump oil system (much preferred for tracking, etc.) and it is very easy to get additional HP out of the motor. The 996 NA motor is just about max'ed out with regard to HP increases, unless you add a supercharger...As an example of how different they are, I believe a new 996 engine from PCNA is about $10-$12K vs a TT motor that runs about $30K.
Enemy
Oct 24, 2015 04:14 PM
takenotes996tt
New Member Introductions
Sep 3, 2015 10:12 AM
bmwtmx
Aug 26, 2015 07:26 AM
John@SpeedTech
Aug 23, 2015 12:07 AM
