Why won't HID lights go on when the engine is off?
Old Feb 22, 2008 | 12:30 PM
PeterK's Avatar
PeterK is infamous around these parts
Is it a feature or are my HID lights going south?
E.g. if I turn on the lights when the engine if off, the HID won't shine. Only when I start the engine, I could get the HID up.
Old Feb 22, 2008 | 12:41 PM
HIGHcard's Avatar
HIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud of
you should be able to get the hid's on when the engine is off...but the key has to be turned to the position right before the position where you are actually starting the car - that should do the trick...if not your screwed JK you should be fine
Old Feb 22, 2008 | 12:44 PM
PeterK's Avatar
Nope, even if I get it to the start position, they won't go on.
Old Feb 22, 2008 | 12:49 PM
wyldstyle's Avatar
wyldstyle is infamous around these parts
wierd....that should have worked
Old Feb 22, 2008 | 12:54 PM
HIGHcard's Avatar
WORD...hmm...
Old Feb 22, 2008 | 01:07 PM
PeterK's Avatar
Well, I scheduled a service visit. What bugs is why do they come on when the engine is running? Could this be a battery issue? E.g. it doesn't give out sufficient power to start them up?
Old Feb 22, 2008 | 02:09 PM
jstgermaine's Avatar
jstgermaine is infamous around these parts
On my 99 with just halogens, the actual headlamps will not turn on without the car running. The parking lights and the daytime running lights work, but the actual head light will not work...I am 100% positive this is how it is designed. Both my BMW and my Mercedes do the same (they have Xenons).
Old Feb 22, 2008 | 02:14 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
Same with my 02TT....if it's not running, the headlights don't light up. Most likely a battery fail safe issue.
Old Feb 22, 2008 | 02:20 PM
HIGHcard's Avatar
yeah thats what i was thinking after you said it wouldnt even light up even when the keys in the proper position for them to light up i would have said schedule a service visit but you beat me to it good luck with that bro!
Old Feb 22, 2008 | 06:21 PM
PeterK's Avatar
Well, it sounds like I need to cancel my service appointment. Yet another problem solved by this forum!
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
turbotuner20v
Sep 11, 2015 12:02 PM
Walorus
Aug 18, 2015 01:39 PM
